Keypad - dead pad
Keypad - dead pad
2016-01-25 by forums@...
Hi all - first post.
Few days ago I got a lovely xl7. Initially the first C pad (normally the kick) did not work at all. I did a full system reset and it started working again but after more messing in the settings, it stopped.
I have done more resets but Im thinking this might have been a red herring and in fact, its just faulty.
So, I took it apart and cleaned the contacts (see pictures in Files -> Keypad) but still no response.
Interestingly, when I first turn it on, the C pad works once (I get sound and the Midi OUT LED flashes) but its then dead (no sound and the LED does not flash).
Questions:
1) is it possible to disable a single pad with a setting somewhere in the OS?
2) if it is faulty, how does the contacts physically work? As you can see from my pictures, its not a standard mechanical switch but rather, the 4 black rubber dots press down on a PCB component that Im not familier with. Ultimately, is it possible to fix this contact?
Huge thanks for any responses..
Re: [xl7] Keypad - dead pad
2016-01-25 by Jon K. Carroll
you can clean the contacts, and it is also possible to re-coat the contacts using several methods. it depends on the exact type of contact, too
Sent: Monday, January 25, 2016 11:36 AM
To: xl7@yahoogroups.com
Subject: [xl7] Keypad - dead pad
Questions:
2016-01-26 by forums@...
Thanks Jon
So, are there any settings that could turn of my leftmost C pad for all presets? Its just very odd that it works the first time I hit it but not again until I reboot?
ta,
