Re: Morpheus Memory
Re: Morpheus Memory
2017-12-13 by smw-mail@...
I just spent about 1/2 an hour looking up the manual and replying in the P2K group. Lemme get you the replies for the benefit of anyone else who is interested. Not sure this will help, but maybe.
ONE:
I have never used a Morpheus, so the sysex data transfer i/o is a bit confusing to me. It does not appear to be as straight forward as the P2K sysex i/o. I have looked at the manual.
From this:
" There is only one edit buffer each for the current preset, the current hyperpreset, and the current midimap. Only one preset, hyperpresetor midimap can be edited ata time via SysEx commands and changing the current preset, hyper or midimap erases the associated editbuffer."
it almost sounds like when you make a dump request, the preset is put into the edit buffer, and then you get it from the edit buffer.
" Preset data may also be transmitted or received in a single block (one complete preset) using system exclusive commands. A preset data request may be issued by a host computer, to which the machine will respond sending the data block for the requested preset. Conversely, the computer may send new preset data which will replace the specified preset currently in the machine."
This seems to be consistent with what I am guessing happens.
(1) Make a request.
(2) The preset data goes into the edit buffer.
(3) The Morpheus send you the data requested from the edit buffer.
However, if I am right, when you send a preset to the Morpheus you might not just be putting it into an edit buffer, but into the slot as well. However, it could be that "the specified preset currently in the machine" refers to just the edit buffer and then the user has to save it before it gets stored. I would hope its the latter. That would make sense when it says that if you change to another preset the edit buffer gets erased.
Command 00 seems to be the preset request--followed by ll mm for the preset number.
Again this is just what I am getting from the manual..
Hope I understand what you are looking for and hope this helps.
Steve
TWO:
From page 252 of 284 in the Morpheus Manual pdf (Rev C) online:
Request preset. Uses preset index values (not the same as program
numbers). Request for card presets will be ignored if card is not
present. Preset numbers are: 0-127 RAM, 128-255 ROM, 256-319
CARD. Values 0x0400+ the bank number (0-2) represent request for
banks. (Banks are blocks of 128 presets.)
F0
SysEx Status Byte
18
E-mu Mfg. ID
0C
Morpheus Product ID
dd
Device ID 0-15
00
Command ID
ll
lsb Preset Number
mm
msb Preset Number
F7
End of SysEx Status
Re: Morpheus Memory
2017-12-13 by rpcfender@...
Sorry about the crossover in the P2k group...
Thanks Steve.
Yes it is a confusing spec. The back section of my manual has more of my writing than theirs.
The Morpheus (and P2k) can retrieve the patch directly without having to load it into the edit buffer (emu seems to call the edit buffer a "Scratch" area)
Unfortunately I haven't been able to request or send the patch in the scratch area of the Morpheus.
Requesting a patch, as you said, is a CMD 00 request with the Patch number and Bank.
User 00 00 to 7F 00
ROM 00 01 to 7F 01
You can get a bank (127 presets) by using the same request with 7F in the Bank position and 00 for user and 01 for ROM
F0 18 0C 00 00 01 7F F7 gets all the ROM presets
In the P2k 7F 7F is the edit buffer, but there isn't a reply from the Morpheus with this request.
All the Parameter requests and sends effects the scratch area so you can get the patch by sending many parameter requests and the reverse to fill the scratch area with a new patch. That is a lot more data and without a checksum (which the bulk preset data has) it is possible there will be data corruption.
As you cursor down the list in my Library program it sends the highlighted patch to the synth 'scratch' buffer for testing. I find this a good way to go through the generated patches after a 'Mix' or 'Morph' as well as when I have forgotten the name of a patch that I need.
I would like to keep this feature, but I don't want to send every parameter separately.
So I could send the bulk patch data to patch 128 and send a patch change message to pop it into the scratch area.
On the other hand I don't want to constantly write to memory like flash that has a small finite life and have it stop working.
I think patch memory is just SRAM in the Morpheus (unlike the P2k), but I would like to be sure from those that know this kind of hardware.
Thanks
Royce
