Saving Presets and Patterns, clarification
2002-06-11 by erik_magrini@Baxter.com
Just to clarify what we're asking for here, before this turns into a
confusing mess ;)
If you are in Pattern Mode (ie the LED labelled Pattern under the main
display is lit up) and you press Save, the default option is "Save
Pattern".  If you are in Preset Mode (ie the LED labelled Preset under the
main display is lit up), then the default option after pressing Save will
be "Save Preset".   The issue I was talking about, is that you can be in
Preset Mode, and be in the Pattern Edit screens still, which could be
confusing if you forget you're still in Preset Mode and go to save your
Pattern changes.  David brings up a good point I didn't think about, in
that you can be in Pattern mode too, and still be changing things in the
Preset Edit menu, which can be equally confusing.
rEalm
I would have to agree with realm on this one.  When I'm editing a preset,
I should be able to hit save and it saves the preset.  Also, it would be
nice if you could "lock" your presets to prevent accidental overwriting :)
