Help MC-505 vs. XL-7
2002-06-24 by vsr123
Folks
      I couldnt find a similar post and am new to this group. I was
wondering if any of you had suggestions regarding a XL-7 vs. an MC-
505 unit from a beginners perspective? Which one is easier to pick up
and understand? I am interested in trying some of my own mixes of
other tracks/samples and then maybe trying something on my own.
thanks in advance for your help
vsr
Re: Help MC-505 vs. XL-7
2002-06-25 by pocketd@gmx.de
I\ufffdm an absolute beginner,too, and I think an XL-7 makes it easy to
understand modulationmatrix, Midi things and the routing things, but you always have
to fight with the manuals and the machine at the beginning, and at least it\ufffds
just music, and music can be much more complex than the technique in that
machine. The manuals are in English, but easy to understand at nearly all points
I don\ufffdt know about the MC-505, his timing seems to be safer,but who knows..
Cy,
Christoph from Germany
Folks
vsr
Tippen, abr\ufffdumen, Million\ufffdr werden! Mit Tipp24.de macht Lotto Spa\ufffd!
http://bonus.gmx.net/?gid=41442879&prid=226
RE: [xl7] Help MC-505 vs. XL-7
2002-06-25 by Andre Lewis
Well IMHO the XL-7 is a little easier to get into at first, but the MC505 has a
lot going for it as well.  The main reason you would want the XL-7 is for it's
sounds and that you can add different soundsets to it.  As far as synths go, the
synth engines are very similar with the exception of the modulation matrix (IE
patchcords) on the XL7, but this might be harder to follow and you may not use
it as much.  The 505 has the equivelant engine of the JV series and XV series of
Rolands, in fact the controllers on the JP8000 map directly on the 505.  The 505
is way more complex overall but has nearly the same general style synth engine
(4 sound layers x effects per layer + filter per layer + 1 of 8 LFOs per layer +
amp, pitch and filter envelope per layer + FM modulation). The 505 has a better
sequencer in that it has a really solid architecture and very well done drum
mode, allows you to mute drum portions without assigning a designated track to
them (The xl-7 requires you to assign each sound to a channel, therefore a kick,
hihat, snare, tom, cymbal, clap and ride will take up 7 channels if you plan on
muting/unmuting realtime).  If you are using these without a computer and you
don't mind the sounds the 505 wins hands down, since it is more mature and has
shortcuts to all functions. If you plan on sequencing with a computer the XL7
takes the cake, since it has a better interface for that.  They both have
quirks, though the 505 really is a comprehensive beast, but very deep and it
will take far longer to learn some aspects.  Live sequencing and recording =
505.  Soundset = XL7.  Effects = 505.  Appregiators = either (The 505 has only 8
user apregiators, however has things like chord mode where the bass notes are
apregiated but the uper notes are chords) so it's a tossup.  Controllers = 505
(Dedicated knobs and sliders for most functions) (XL7 = 18 knobs, no sliders -
505 = 26 knobs and sliders).  Keypad = XL7 with it's dynamics and aftertouch.
Extras = 505.  Pattern sequencer = 505. Track count and extra midi channels for
other gear = XL7. Crashes = both. Timing = both.  You have to play with both of
them a little to get the best timing.  Beats mode doesn't compare to RPS or
megamix, but RPS doesn't transmit midi.  The main drawbacks of a 505 are that:
1) it's complex, maybe too complex. 2) The sounds sound a little thin by default
unless you tweak them. 3) The two line display makes editing note events suck.
4) The 505 has no dedicated thru.  5) You only have 8 channels + RPS, however
this can effectively be the equivelant to 16 channels depending on how you use
them.  6) The filters can blow out your speakers and tend to overload your
inputs if overdone.  7) The filters and other knobs can sometimes have noticable
steping.  8) The sequencer can get bogged down with too much controller info and
slows down, though this is easily fixed by shifting events over a few clocks.
8) there is only 3 effects busses, 1 reverb, 1 delay and one multiblock.  If you
skim this list you will see that there are many small workflow issues and minor
bugs for the XL7, and it misses a lot of the functionality of the 505, however
it has one thing the 505 doesn't:  A team of dedicated people willing to listen
to the customers and release new features regularely.  The 505 has years of this
style of sequencing under it's belt, but it's not perfect.  the XL-7 is still
relatively new but has the ability to really grow into it.  I personally have
them both and have no interest in getting rid of either.  In fact they work well
together and accentuate each other.
Hope that wasn't too confusing ... ?
Andre
Sent: Monday, June 24, 2002 1:27 PM
To: xl7@yahoogroups.com
Subject: [xl7] Help MC-505 vs. XL-7
Folks
vsr
Re: [xl7] Help MC-505 vs. XL-7
2002-06-26 by David Jones
To me they are two compeletely different machines that funciton worlds appart. The MIDI functionality of the MP/XL-7 is amaizing. The megamix function in the 505 is cool, but imho it's about the onlything that is slightly better than the xx7. READ: You have the ability to program up to 32 tracks internally and 32 tracks externally in the XX7. Imho xx7 wins hands down...
Sent: Tuesday, June 25, 2002 5:01 PM
Subject: RE: [xl7] Help MC-505 vs. XL-7
Andre
Folks
vsr
2002-06-26 by Andre Lewis
Oh there are other things like custom drumkits, custom rps kits (Any pattern can be played as an RPS key, basically combining as many as you need realtime) the realtime pitchshifting of the entire pattern as well as each part, the D beam controller with oodles of scales, groove quantize, shortcuts for everything, call patterns for making your patterns easily accessible, and accent levels. If all you really want is a thirty two channel sequencer get an older laptop and a USB midi 2x2... ;) But like I said the XL-7 is a great piece of gear and loads of fun, sounds great and easier to come to grips with than the 505. I wouldn't get rid of mine for the world.
Andre
Sent: Tuesday, June 25, 2002 11:00 PM
Subject: Re: [xl7] Help MC-505 vs. XL-7
Andre
Folks
vsr
2002-06-26 by Nick Rothwell
> As far as synths go, the synth engines are very similar with the
> exception of the modulation matrix (IE patchcords) on the XL7, but
> this might be harder to follow and you may not use it as much.
...in other words, the XL-7 is far superior as a synthesiser, what
with the Z-plane filters, clock-based modulation matrix, arpeggiator
integration, etc. etc. I bought my XL-7 based on my experience with
the Morpheus and Audity, so the MC-505 wouldn't have impressed me much
at all.
In general, Roland stuff sounds lovely (and they have good preset
designers), but they've always been a little quirky and arbitrary when
it comes to control structures and modulation architectures. Their
user interfaces are varied, ranging from useable to execrable.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
to me it's easy.
505 = fisher price
xx7 = Porche
I have owned the 505 in the past, and it was a decent unit. But the xx7 architecture is so advanced in comparison.
Sent: Wednesday, June 26, 2002 4:13 AM
at all.
2002-06-26 by Byron
I just bought my XL7 (like last week), so maybe I can give you a fresh
user's viewpoint of it comparitively...I have only used a 505 a few times,
but have used the mc-303 a bit more in depthly, and must say right off of
the bat, the only thing I really found appealing about the 505 was the light
sensor modulator...if Roland were a bit wiser, they would release a
standalone ligth sensor that could be programmed to modulate any form of
midi cc#, THAT I would buy! The only 3 things roland has released in the
last 6 years or so that have even slighty kept my interest were the 8080,
the dj2000, and the almighty mc-80 (which, I might add, I would have bought
instead of an XL7 if it had much larger ram capacity for midi notes).
In any case, enough babble, the XL7 IS great at what it does, but is fairly
bizarre to understand at first, mostly because the interface is very
lacking, imho, in intuitive natural controllability. Yes, it's internal
sounds are great, fairly flexible programibility for them as well (much more
than I had expected)...the resonance of the filters blows total chunks
though....a tad bit glitchy here and there still as well (digital hiccups
and what not). The sequencer is great and easy to use, the arpeggios are
extremely flexible in terms of programming, more so than any I've seen, and
you (seemingly) have alot of control over, well, alot of stuff. My biggest
complaint about it, is that everything is primarily orientated towards
useing the internal rom sound...I'm talking like a 80 to 20% lean
here....this box just dosnt like to play all that well with others. At first
I thought the thing was buggy, but am slowly learning thats it's more that
it's just wierd and unnatural in it's ways. Alot of things you may want to
do (like control your external synth with an arpeggio, setup a blank pattern
to be used for external gear, or even just changing some of the preset roms
in a pattern without changing them all) are all possible, but require a
large amount of sweet talking and finagleing work arounds in time consuming
and just down right odd ways...imHo, many of these things should be second
nature to it, but it seems more like it was designed with these things on
the back burner so to speak, almost like they were last minute additions to
it that were not integrated very thouroughly into the flux of things.
Oh, yea, the key pads blow as well.
All that aside, if what you are looking for is a 'groove' box on steroids,
then the XL7 is definately it...it blows the competition out of the water in
those regards. If all I wanted to do was make partially pre-programmed music
using only one synth engine, so that all of my music would have an uncanny
similarity to it, then this would by far be the box to do it with.
ByronE
Chaos exists as raw material from which to create order.
-Reverend Mother Superior Darwi Odrade
Sent: Monday, June 24, 2002 3:27 PM
Folks
vsr
Re: Help MC-505 vs. XL-7 - Andre and all
2002-06-26 by vsr123
Hi Folks
         First of all thanks to everyone who responded so promptly on
this topic, that certainly gave me a lot of information especially
the posts from Andre. I had one question on what was said in that
port - which is copied and pasted below----
mature and has
computer the XL7
Q) I thought the sequencing capability is good on an XL-7 , if  I use
a software sequencer then
1) How easy is it to port between the PC and how easy is it to input
external samples into EMU? How easy is it to input samples into the
505 from the computer?
2) Also if I use the software sequencer than am I using the EMU to
create only my basic drum patterns, modify the built in samples and
export it to the PC where I do my sequencing? I am not sure what
strengths lie in the EMU apart from this if I dont use the unit as a
sequencer?
thanks again for all your help
vsr
MC505 has a
is for it's
synths go, the
matrix (IE
may not use
XV series of
505.  The 505
synth engine
LFOs per layer +
has a better
done drum
designated track to
therefore a kick,
you plan on
computer and you
mature and has
computer the XL7
both have
deep and it
recording =
505 has only 8
notes are
Controllers = 505
no sliders -
aftertouch.
channels for
with both of
to RPS or
505 are that:
thin by default
events suck.
RPS, however
how you use
overload your
have noticable
controller info and
few clocks.
multiblock.  If you
issues and minor
505, however
willing to listen
years of this
7 is still
personally have
they work well
> Andre
> From: vsr123 [mailto:vsr123@y...]
> To: xl7@y...
> Folks
up
> vsr
> xl7-unsubscribe@y...
RE: [xl7] Re: Help MC-505 vs. XL-7 - Andre and all
2002-06-27 by Andre Lewis
Well the simple answer is that these machines don't allow samples to be uploaded
into them.  They both expect you to have a sampler to play back custom samples.
They do have loads of samples on board to choose from or make your own sounds
from as patches.  There are tools to manipulate these on the computer and save
these patches to the units, and in the case of Emu, you could pick up one of the
more expensive EMU samplers and burn your own samples to a card for the XL-7
however this means buying a sampler in addition anyway, so there is little need
to buy the additional card.  Luckily sampler are extremely cheap right now and
many are very full featured (I suggest a Yamaha A4000 or the EMU ES series as
they are currently extremely cheap).  Bear in mind that the Emu also has premade
sound libraries you can add to the machine, up to four slots total.  Each one
adds patches based on the stock samples of the card, and you can make your own
patches by combining stock samples from multiple cards.  The 505 allows you to
save patches, and also has a smartmedia expansion to save patterns/patches but
is limited to the sounds allready onboard.
sequencer?
The Emu has a well made sequencer, and as people have pointed out the XL7 has a
32 track sequencer, however (I may be wrong, I haven't checked the newest
features on the OS update) you currently have no way to quickly mute/unmute
channels above the sixteen in group A (There are thirty two logical tracks in
two groups of 16 - Group A and Group B).  The mute buttons are assigned only to
group A, meaning that if you want to modify the loop structure you will have to
copy everything over to the new pattern and erase the data on those tracks you
want muted in group B (the extra midi out port).  In addition people have to
jump through some hoops to do the mutes during a song as well, although all of
this is currently being worked on.  What this all really means is that for basic
recording you will be fine, but if you want to do any serious midi recording you
could start on the XL7 but you would want to finish on the computer.  Most
people do this anyway regardless of the hardware.  The 505 has the same basic
sequencer as the MC80 hardware sequencer, except for the track limitation and is
therefore mature and very intuitive once you understand it.  Probably too much
to understand at first but you apreciate features on it like undo.
As for the other things out there, such as the electribes, most are very
simplistic and are limited in order to keep costs down.  You will find that the
Electribe ES1 can do crazy stuff because you can use samples and it has probably
one of the easiest and straightforward sequencers out there, but it won't really
compete with an XL7 or 505 with a decent sampler.  Here is a very decent piece
of advice from the Chemical Brothers:  You can make incredible music with
anything if you really understand it's limitations and make it go beyond it's
original use.  The Roland TB303, TR606 and TR808 were never up to snuff compared
to a real bassist or drummer, but look how many dance albums star these
machines!  And they don't even have midi!  I suggest playing with the XL7/MP7
and the MC505 and the Yamaha RM1X and see which one inspires you the most, You
will be able to grow into them and really make them shine if you spend the time
on them.  On the 505 scroll to a different preset, the default channel for the
pads is channel 2, the bassline, but the keys play up two octaves by default and
it sounds dorky.  On the XL7 press preset under mode/view and use the track +/-
next to the screen to change tracks to audition sounds.  Press pattern to change
patterns.  Use the audition button to check out a demo of the sounds on each
track.
I don't want people to think I'm knocking the XL-7, far from it. I think it's
incredible and getting better.  I just know I won't be getting rid of my 505
anytime soon (Had it for three years now) because one it is very flexible and
two it keeps surprising me.  Both the XL7 and 505 are smarter because they
started with a full featured synth engine and then tacked on the sequencers and
performance aspects so they are much deeper than they look.
Good luck,
Andre
2002-06-30 by constantradius
I have both...if you are composing original material then go with the
xl-7, if you want prepackaged backgrounds with a good bit of extras
grab the 505.
--- In xl7@y..., "David Jones" <spec@s...> wrote:
> to me it's easy.
> 505 = fisher price
> xx7 = Porche
>   ----- Original Message -----
>   From: Nick Rothwell
>   To: xl7@y...
but
arpeggiator
with
much
>   at all.
when
Service.
2002-07-12 by noision1
I have the MC-505 as well and have been using it for a while with
the XL-1 for the nice sounds that are essentially the same as the XL-
7. I decided to purchase the XL-7 and sell my XL-1 because of the
recent price drops and rebate, because the difference in price is
not probably less than to upgrade to a turbo XL-1 and this way I get
the extra knobs and a sequencer with a fancy light holder built in!
But I have to echo and respect Andre's very good and detailed
comparison between the MC-505 and the XL-7. Soundwise, it is just a
lot fresher. Sequencing-wise it seems to have more brute force,
i.e., the 32 channels internal and external etc, but in terms of
subtle, yet hightly useful and musical, features, the MC-505 is far
more of an sequencing powerhouse. For live work, the MC-505's
ability to allow you to effortlessly tweak tunings, levels, filters,
etc of individual drum sounds, snare, hi hat, whatever, whether in a
pattern, or even in an rps you are flying in, is not to be
underestimated if you enjoy true flying by the seat of your pants
live work. Sure, in order to have a great set, both the E-mu and the
505 require you to prepare and set up a basic library of patterns,
etc, but once the lights go on, with the E-mu, you are pretty much
relegated to mutes/unmutes, etc and tweaks on tracks as a whole.
With the 505 you can go off the deep end much more but hold it all
together, if you feel you need to adjust the resonance on that
cowbell clanking away or make it echo out, you need not have
previously assigned it to its own track, you can hold down its
keypad and tweak it, etc. Maybe it seems esoteric, but many small
freedoms can add up to a whole lot of power.
I am glad that E-mu is on board to continue to make things better
and implement feature request that they can. I do fear that many
large wishes, such as things resembling rps or megamix are probably
not going to happent because they seem to be quite off the
conceptual horizon of these units the way they are now, and probably
would require a gutting of the O.S. code which is likely never to
happen.
However there are plenty of small things that have been done and
probably can be done that is and will make things alot better than
at day one and as long as E-mu stays with it, I am sure that the
sequencing will progress along well.
For example, things like making the knobs in Volume/Pan Mode be able
to address the midiB channels will be very welcome so we don't have
to simply just look at that second row of indicators in the Mix View
for nothing--ESPECIALLY when if you assign say a particular track in
pattern mode to a different midi channel, i.e.,  track 15 is Channel
2B (instead of normal 15A), then when you put the knobs in Volume
mode and turn knob 15, it nonesensically adjusts the volume for
channel 15a instead of 2B. This hardly is useful and basically means
that unless you use channels 1A-16A for everything, you lose much
realtime tweakability. Things like that need to be ironed out.
While I am leveling some minor criticisms, the harshest thing I have
to say is, what is the furor about beats mode!? At first
surprisingly the XX-7's didn't have the beats mode that is standard
in the XL-1 and the rest. Now with O.S. 1.31 it looks like E-mu did
good and spent considerable time and energy to get the whole beats
mode in there. Bravo, well, maybe not. Is it just me or has beats
mode, since its inception over two years ago been universally
recieved and reviewed as pretty much a neat but basically useless
feature, and not just because you can write your own riffs? Is
anyone here honestly rocking and rolling with the beats feature not
that it has arrived in O.S. 1.31. If so, speak up and let us know
how it is more than a novelty to while away time when nothing else
is happening.
Writable, or at least definable riffs are the key I think to a lot.
If E-mu would implement a way to define a melodic riff as whatever
is on a specific track of a specific sequence, then you would have a
beats mode that you can write yourself by making patterns. The next
logical step is to allow the trigger buttons to trigger such riffs
and then you are in bigtime RPS territory.
Nonetheless I do not regret my XL-7 purchase at all because the
price point has made it a no brainer fancy upgrade from my XL-1 and
I like the extra outs and all. If I had sold my MC-505 I probably
would be feeling somewhat distressed right now though. Good to have
both!
Ravi
p.s. the only thing I worry about on lists like this that are
blessed with company presence and input is that some members are
either scared or intolerant of even slightly negative posts like
this one and end up shouting down all dissent to show props for the
company staff on board etc. (see unnamed german synth list starting
with a W). Well I know Sean and others can take it and I expect they
know that this post is meant to in all good spirits and not to
condemn. Everything has room to improve. To contrast, on the MC-505
list, we KNEW that Roland was permanently absent and as such we
often had a real unadulterated good time bashing the hell out of
every flaw we could find, no matter how much we liked the dumb box.
Don't be afraid.
use
input
to be uploaded
custom samples.
own sounds
computer and save
up one of the
for the XL-7
is little need
right now and
ES series as
also has premade
total.  Each one
make your own
allows you to
a
> sequencer?
the XL7 has a
newest
mute/unmute
logical tracks in
assigned only to
will have to
those tracks you
people have to
although all of
that for basic
recording you
computer.  Most
same basic
limitation and is
Probably too much
are very
find that the
it has probably
it won't really
decent piece
music with
beyond it's
snuff compared
these
the XL7/MP7
the most, You
spend the time
channel for the
by default and
the track +/-
pattern to change
sounds on each
> track.
think it's
of my 505
flexible and
because they
sequencers and
> Good luck,
> Andre
Re: [xl7] Re: Help MC-505 vs. XL-7 - Andre and all
2002-07-12 by erik_magrini@Baxter.com
For live work, the MC-505's ability to allow you to effortlessly tweak
tunings, levels, filters, etc of individual drum sounds, snare, hi hat,
whatever, whether in a pattern, or even in an rps you are flying in, is
not to be underestimated if you enjoy true flying by the seat of your
pants live work.
>>>Agreed Ravi, the mc505 is much better at letting you control your set
flow and experiment live, while keeping everything under wraps.  The
XX-7's pretty much require you to have your entire set preplanned, in
order to do it smoothly.  However, let's not forget summer NAMM starts
next week, may EMU have some surprises? <<<
p.s. the only thing I worry about on lists like this that are blessed with
company presence and input is that some members are either scared or
intolerant of even slightly negative posts like this one and end up
shouting down all dissent to show props for the company staff on board
etc.
>>>see the archives, there was plenty of this going on before the OS 1.31
upgrade :) <<<
rEalm
