just my opinion?
just my opinion?
2002-08-16 by pocketd@gmx.de
If you record realtime controller data, should the Quick edit controllers be
set to the initial controllers or not? I\ufffd\ufffdm not sure if it changes anything,
I think it comes out the same....but...
That\ufffds that MAX/MSP, please tell me more.
So that I use the XL-7 for some time here\ufffds my opinion: (and it\ufffd\ufffds not too
good)
-Take a Roland 303, there\ufffd\ufffds the way to change more controllerdata than just
velocity using grid edit, so that fact is bullshit.
-Using realtime record on XL-7 changing controllers is not to comfortable,
what you also hear is the turning of knobs, (don\ufffdt want to hear that
sometimes) so if I have done a new track with a controller movement and I make a
second pattern recording new controller data on same channel, same controller but
other track, now it can really get to bad parameterbreaks, cause you really
don\ufffdt know exactly where that contoller is at the moment, sorry, but that\ufffds
all bullshit, too.
I\ufffdm using Logic instead to record controllers, perhaps I bring it back
sometimes, but that\ufffds just so unmusical process. Using a SQ-16-3 in Logic is more
comfortable.
-Recording pan and volume, hmmm, I\ufffdm doing that on my mixer, brings more fun
or modulating pan and volume.
- The Effect unit, don\ufffdt talk about that, take a Korg Kaoss Pad and you know
what I mean, the only thing I use it for to add some hall or delay, but
there\ufffds the problem of no dry signal, here is no good way to make a flexible
effect control, really , really old technique from E-MU.
-The grid edit don\ufffdt works on external sources, the note always goes back to
C-1, obviously a mistake in the software.
So, why I bought that?
1. I\ufffdm a beginner and did not know too much about sequencing that time.
2. The modulating architecture of E-MU is the most professional one, that\ufffds
a fact, you can do everything with everything to everything, brilliant.
3. Filterarchitecture is great, too.
But (don\ufffdt be sad) I think it could become a really good one, cause that\ufffds
all depending on the software, I hope a lot it\ufffds changing at an update, and I
hope they do the right things,
Cy,
Christoph
"Techno? What\ufffds that?" - LX Paterson
1Apreis - das Online-Paradies f\ufffdr Schn\ufffdppchenj\ufffdger!
http://bonus.gmx.net/?gid=41442879&prid=348
Re: [xl7] just my opinion?
2002-08-16 by erik_magrini@Baxter.com
set to the initial controllers or not? I´´m not sure if it changes anything,
>>>It doesn't matter, it'll record the knob movements either way. <<<
That´s that MAX/MSP, please tell me more.
>>>It's a programming utility to make your own MIDI "software objects". It's very complex,a nd in a way is a lot like computer programming in order to get usable results. Not at all for beginner IMO, but you can do some intersting things with it if you like programming from what I've read. <<<
-Take a Roland 303, there´´s the way to change more controllerdata than just
>>>You can also use List Events to edit CC's, it's the third to last menu under Pattern Edit. <<<
what you also hear is the turning of knobs, (don´t want to hear that
don´t know exactly where that contoller is at the moment, sorry, but that´s
all bullshit, too.
>>>Sorry, I don't understand what you're trying to say! <<<
- The Effect unit, don´t talk about that, take a Korg Kaoss Pad and you know
there´s the problem of no dry signal, here is no good way to make a flexible
>>>You can set one of the busses to 0% if you need a dry signal. <<<
-The grid edit don´t works on external sources, the note always goes back to
>>>See Aaron's post on this yesterday. <<<
rEalm
