installing ... PURE PHATT SHIT ...
2002-10-11 by pawelmr
Hi, just got pure phatt shit rom and I can't uploaded patterns its
saying .. (not installed) ???? what should I do ?
Re: installing ... PURE PHATT SHIT ...
2002-10-11 by M2
Make sure that you have the ROM oriented correctly in the unit.  I
posted in the files section a ROM installation document that was made
available by E-MU.  There is a notch on one side of the ROM, make
sure that it is in the same way that the factory ROM is.
 http://groups.yahoo.com/group/xl7/files/
It's labeled XLMPP2500ROM.pdf
2002-10-11 by anhqaz
Real easy
 All you have to do is load  midifile patterns into software
sequencer then look up on yours MP7 to find out what bank# does pure
fart locate (press audition button).Now edit yours software to the
same bank# you see then save these pattern ass a midifile format
1 .finally use yours eloader do dump it to MP7 as usual.
  good luck
   anh
made
>Anh wrote:
>Nah,it's not that,see my procedure on the next messege.u need a
software sequencer to tweek bank# that's all
its
2002-10-11 by M2
Well, he wasn't clear as to if it was the "user not installed???" or
if it was not recognizing the ROM itself.  If he doesn't have a
software sequencer, he can go to www.midiox.com to get a freeware
version just for pattern downloads.  There is a playback only utility
in it that I use.
I
> made
> its
Re: [xl7] Re: installing ... PURE PHATT SHIT ...
2002-10-11 by Nick Rothwell
Alternatively, attempts to bank-select to bank numbers not
corresponding to the currently installed ROM's will also generate a
"not installed" message.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
2002-10-11 by M2
Correct also, I was just just having him check the hardware portion
since most of the problems are not always software related.
or
FIRST YOU ARE ALL COOL !!!!!!!! THANKS BUT :::
I can play presets means rom is installed corectlly
PROBLEMS is with PATTERNS form MP7 when I loaded using either
cubase or emu loader pattern and play and preset keep saying NOT
INSTALLED HEEEEEEEELP before I smashed this BABY :) PEACE ALL
2002-10-11 by Sean Wilhelmsen
The Pure Phatt ROM has a different ID number and different preset
locations that the MP-7 ROM. MP-7 patterns will not play using the Pure
Phatt ROM. Contact E-MU service, they may be able to provide some type
of solution.
sean at e-mu
> To unsubscribe from this group, send an email to:
> xl7-unsubscribe@yahoogroups.com
