New idea?
2002-10-10 by erik_magrini@Baxter.com
Hmm, had an interesting idea for a new EMu product that would compliment the XX-7's nicely. What about a small dedicated sample playback unit for use with the Command Stations (call it the SP12 or something) ? Say a half rack size unit that has the very minimum of connectors. On the back, MIDI IN and THRU, USB, power connector, and maybe 6 outputs. The front would have MIDI indicators, a volume knob, and maybe a 2 line LCD for the most basic of info. The top would have a small panel you could remove to add more memory DIMM's. It would be for use with a software interface in order to set up your samples, do all your looping and keymapping etc. Basically, it would be a really cheap, and portable sample playback unit. Similiar specs as say a low end Emu rack sampler, but without the onboard control and expansion options to lower the price. All you'd need to do is set up your samples via spftware, then transfer them to the box for when you want to play out live. Yes, I'm daydreaming I know.... rEalm [Non-text portions of this message have been removed]
