Re: [xl7] Digest Number 464
2002-10-31 by S V G
Byron,
Thanks for the advice. I checked out the sound recorder that comes with my sound card and it
records a whopping 60 seconds. Short of limiting my piece to this time frame, does anyone have
any ideas as to how I can get analog line in from my XL-7 to a .wav file on my puter?
SVG
Yes, that would be a wav file you need. You don't need any fancy program's
or virtual studios just to record a single stereo track....just run the
stereo main outs of your xx7 into the line-in of your sound card (you'll
probably need a stereo rca to 1/8" jack audio cable with 2 mono 1/4"
adapters for the rca side...or something that equivelates to the same). Then
use an audio recording program to record the line-in input. Your sound card
surely came with at least a simple one. Since we're only doing raw direct
recordings, no pre/post mastering, you don't need any extravegant programs.
Then take the wav file the recording produced and open it up in LAME and
compress it into a a 44khz mp3, was 192kbps the highest rate of encoding? If
so, use that setting for best quality results.
Do you Yahoo!?
Y! Web Hosting - Let the expert host your web site
http://webhosting.yahoo.com/
