Got it, finally!
Got it, finally!
2001-10-26 by erik_magrini@Baxter.com
OK, so I finally got to pick up my XL-7 last night, after weeks of trying
to get one.   Man I was getting sick of reading the manual without having
it to look at :)  Anyway, I'm so happy with the purchase so far, very nice
unit.  It was a snap to be up and running, making new pattern and writing
my own patches.  BUT....I did run across some thing I have some questions
about.  Not too sure if I'm missing something (checked the manual a few
times already), or if these are bugs, quirks, etc...  Maybe you guys can
let me know what deal is with these:
1. I love how you have access to everything while playing the pattern, or
even recording.  But why do you have to stop playing a pattern in order to
enter grid recording?
2. This seems like a total ommision, how do you copy just one measure from
say an 8 measure pattern?  If I'm playing a part and happen to nail it
better in one measure versus the others, I'd want to be able to copy it
across the whole pattern.  Same with any controller tweaks, is this
possible?  I suppose I can throw it in Cubase and edit there for now, but
it would be nice to be able to do it from the front panel...
3. Thanx for the reply about the knobs jumping to new settings when you
tweak them, but it would be nice to be able to toggle between that mode
and having to pass the current value before the knob takes effect.  this
would eb pretty easy to implement in the Controllers menu I would think.
Anyway, thanks for all the help so far, this thing is one killer box!
rEalm
Re: Got it, finally!
2001-10-26 by ppc_@hotmail.com
Hello rEalm,
will check if I'm in trigger mode later today.
pattern, or
order to
Press and hold Play and then press Record to enter grid recording
(page 62 in the manual).
Sorry, don't know the answer to your other questions.
/Jon
Re: [xl7] Got it, finally!
2001-10-26 by Aaron Eppolito
There's an "extend" feature that will do this very quickly for all the
tracks you select.  Say you're working only in the first measure, and
you've laid down a basic groove.  You can choose "EXTEND SEQUENCE DATA
TO" bar:8, and it will loop the data as many times until it fills the
space.  See page two in the addendum...
-Aaron
> from say an 8 measure pattern?  If I'm playing a part and happen to
> nail it better in one measure versus the others, I'd want to be able
> to copy it across the whole pattern.  Same with any controller tweaks,
> is this possible?  I suppose I can throw it in Cubase and edit there
> for now, but it would be nice to be able to do it from the front
> panel...
2001-10-27 by drk@delora.com
Yes, extend does duplicate a measure (or whatever length you
select starting from the beginning bar.  But it duplicates by
merging into the track.  So if you have something say recorded
over four measures and only want the first measure, duplicated
over four, you will need to erase the last three measures first.
But there is no easy way to do this!
You can reduce the pattern length, copy to the clip board, paste
to a temp track, erase (via cut) the original track, but with the
longer length, reverse the cut and paste, and the extra three
measures are still included.  So I do not believe there is any way
to excerpt only a portion of a track and then use that further.
Please someone correct me with a practical work around.
drK
2001-10-27 by mikexl7@yahoo.com
ya I have the same question.
I have been working with this box for about 2 months now and still
don't know an easy way to do this.  I just erase it and re-record my
pattern till i get it right but that is not always the easiest thing
to do.  I am fine with the beats but when it coms to playing chord
patterns it is another thing all togeher(I am not a great keyboard
player).
Having more peramiters associated with the copy feature would be a
great thing to add in the new OS.  like sompting to the effect of
copy from-slect begining/select end.
I am a little tired so bare with me but another thing i noticed is
that when i copy a one bar loop and copy it into a existing four bar
loop i cant extend the one bar loop to fill all four bars, and i also
cant paste it in four times.  This is very anoying.
Another thing i am noticing that i dont know how to fix is....
When i use the defaullt preset to make my own instrament when i use
the Filter Q quick edit knob it dose not change the sound till the
next note is played rendering it usless when i need it most.  I use
it most often to thin out a fat leed or pad wile holding down a chord
or note.  How do i change this?  anyone know what i am talking about
here?
hope to hear some feed back on this one.
P.S.  i realy appreciate this board, it is nice to watch it grow :)
thanks for your time, now its bed for me.
> drK
2001-10-29 by erik_magrini@Baxter.com
Thanx, just what I was looking for!  Er...well closer to what I was
looking for :)  What about if I have a measure in the middle of a pattern
I want to keep and copy for whole length of the pattern, anyway to do
that?
rEalm
