[xl7] Why wont effects save sometimes
2002-12-16 by jm213213@aol.com
sometimes when recording a pattern after ive saved and try to play it back some of the quick edits i made change back to their default. why does this happen sometimes? [Non-text portions of this message have been removed]
2002-12-17 by erik_magrini@Baxter.com
If you make any changes to the Quick Edit Knobs, you need to save the
Preset, not the Pattern.
rEalm
jm213213@...
12/16/02 03:12 PM
Please respond to xl7
To: xl7@yahoogroups.com
cc: Subject: [xl7] Why wont effects save sometimes sometimes when recording a pattern after ive saved and try to play it back some of the quick edits i made change back to their default. why does this happen sometimes? [Non-text portions of this message have been removed] To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
2002-12-18 by jm213213@aol.com
ok so everytime I use the quick edit knobs I need to save the preset as well as the pattern? Another question I have is about the appegiators. If I change the M set do I have to save it or will it save it automatically? thanks you make any changes to the Quick Edit Knobs, you need to save the Preset, not the Pattern. rEalm [Non-text portions of this message have been removed]
2002-12-18 by drK
On 12/17/02 11:52 PM, "jm213213@..." <jm213213@...> wrote: > ok so everytime I use the quick edit knobs I need to save the preset as well > as the pattern? Another question I have is about the appegiators. If I > change the M set do I have to save it or will it save it automatically? > thanks > > There is only one possible set of master arpeggiator settings so by default any changes you make to these are remembered. There is no "save" operation for them. One additional comment on the QuickEdit knobs. When you edit a preset using QuickEdit and switch to another track with a different synthesizer channel being used you will loose those changes. This is also true of any edits at all done to the preset. There is only a single edit buffer used for the entire XX-7. So something as simple as hitting the TRACK/CHANNEL plus/minus buttons can cost you your edits. So if your doing a lot of tweaking and switching tracks back and forth you need to get in the habit of hitting SAVE/COPY before changing tracks/channels. drk www.delora.com/music www.mp3.com/zdrk drk.iuma.com
I have another question regarding saving a preset... say I tweek kit-1 and go to save preset.. I save it as kit-1 under user.. what happens if I decide to tweek kit-1 again in the future on a different pattern.. Will these changes be distinguished in each pattern or will the changes just be on the last save I did only? [Non-text portions of this message have been removed]
2002-12-18 by erik_magrini@Baxter.com
If you tweak and save Preset, regardless of that the Pattern is, the new
Preset definitely overrides the older one (which will be gone forever).
Because of this, I always rename and save my Presets to a new location if
I use them in a different Pattern. There's nothing worse than working on
a new pattern and tweaking a bunch of presets only to realize you
accidentally saved over a Preset that was being used in another pattern.
Another reason I back up my Presets to SX when I'm done working on the
XL-7, at least that way I can always go back and reload the last saved
bank I had. I do wish Emu would come up with a more elegant solution
though, being able to do it all in E-Loader would be SOOO much easier!
Especially if you could pick the Presets you have saved, and choose where
they will download to in the XX-7 like you can with Patterns.
rEalm
jm213213@...
12/18/02 10:47 AM
cc: Subject: Re: [xl7] Why wont effects save sometimes I have another question regarding saving a preset... say I tweek kit-1 and go to save preset.. I save it as kit-1 under user.. what happens if I decide to tweek kit-1 again in the future on a different pattern.. Will these changes be distinguished in each pattern or will the changes just be on the last save I did only? [Non-text portions of this message have been removed] To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
