realtime recording while triggering form external sequencer
2002-12-31 by synthman2003 <rgerards@home.nl>
Hi all, I have the following question, I use a Doepfer MAQ16/3 sequencer as master that runs a sequence. It starts/stops the Xl7 and regulates tempo. The Xl7 also runs a pattern. Further the xl7 midi out-a is connected to a MS10 synth (with midi ofcourse) on track/channel 12a. Now I am trying to record in realtime with the Pads on the Xl7 a melody for the MS10 while both sequencers are running. This does not work properly. I dissabled the rechannelize input and even the midi merge funtions for both midi outputs of the XL7. But still a lot of garble is recorded into the track 12a and subsequently sent to the ms10 that plays it. I don't know where this garble comes from, I guess my maq16/3, but it sends only on channels 1,2 and 3, but that shouldn't matter as I am recording on track 12a and dissabled the allready mentioned features. How come there is still data "leaking into" the Xl7 track 12a? thanx!
