Problems with Windows ME and E-Loader
2001-11-08 by bruce@sigalarm.com
Just wanted to pass on that I have been trying to install ELoader on
my Windows ME powered Laptop.  I see that it is using
InstallAnywhere, which uses Java (I think).  This laptop gets used a
lot when I am at the customer site debugging their Java stuff.  So it
has JDK 1.3 on it.
Any ideas what could be going on?
Bruce
Re: [xl7] Problems with Windows ME and E-Loader
2001-11-08 by Scott Ruda
> has JDK 1.3 on it.
> Bruce
What kind of problem are you having? You are saying it is a problem with the
installer, not E-Loader itself, right?
Is there any error reported? I had a report of problems when trying to
install and there was a very down rev version of the Microsoft JVM on the
machine. Updating to a newer JVM fixed it for that tester. But if you have
the Sun 1.3 JDK on your machine, that should be fine.
Scott
Re: Problems with Windows ME and E-Loader
2001-11-09 by bruce@sigalarm.com
The problem is with the installer on this machine. Not sure about
Eloader yet, have yet to get it installed.
There is no error code, even when running the installer from the
command line, also no errors in the java console.
Bruce
> > has JDK 1.3 on it.
> > Bruce
with the
on the
you have
> Scott
Re: [xl7] Re: Problems with Windows ME and E-Loader
2001-11-09 by Scott Ruda
You're saying that you double-click on the file named
ELoader_1.0_Installer.exe and absolutely nothing happens? No application
launches, no error message?
Note that the Installer itself is not a Java application, it is a native
Windows application. It does not need Java in order to run. At some point in
its work, it will want to access a Java VM, but if it can't find one, it
should be able to tell you that it can't find one, just like any other
Windows application that can't find a DLL or whatever.
Maybe we should take this discussion off-list, because it sounds like there
is some problem that is very specific to your machine. If we find some
information that would be valuable to others, we can always post our summary
findings.
Scott
2001-11-09 by nifflas@musician.org
I want to know why the E-Loader software isn't a native
Windows application... I don't know why, but I don't trust java
100%...
I'm having trouble as well, it looks like the sysex messages get
distorted all the time (both MIDI in and out), so there's no way to
transmit a pattern from or to the XL-7.
I didn't have that problem when I connected the Waldorf Microwave XTk
to the same computer and made a couple of sysex dumps.
Perhaps something with the soundcard. It's quite crappy thing. MPU-
401 btw. Perhaps something about the E-Loader software? I want to
find out. All I hope is that it isn't my XL-7, it's enough buggy
already...
//Nifflas
application
native
point in
one, it
other
like there
some
our summary
> findings.
> Scott
2001-11-10 by Scott Ruda
Can you tell me a bit more about your failure symptoms? You say sysex
messages are getting 'distorted'. How are you coming to that conclusion? Are
there error messages reported?
Note that thousands of users are using E-Loader and it is working fine for
the vast majority of them. The more information you give me the better I can
help you figure out why your system is having problems.
Scott
2001-11-12 by erik_magrini@Baxter.com
Scott,
I ran into this same thing over the weekend (Although I'm using Win98se).
E-Loader would occasionally not transmit my patterns to the XL-7 properly,
or give me an error mesage saying the pattern was not successfully
downloaded.  If I rebooted the PC, then it would work fine.  Weird!
rEalm
Are
can
Scott
2001-11-13 by Scott Ruda
On Monday, November 12, 2001, at 05:24  AM, erik_magrini@...
> Win98se).  E-Loader would occasionally not transmit my patterns to the
> XL-7 properly, or give me an error mesage saying the pattern was not
> successfully downloaded.  If I rebooted the PC, then it would work
> fine.  Weird!
If this happens again, please open the Message Console, save the
contents to a file (select Save from the File menu) and send it to me.
This will help me understand what is going wrong.
Scott
2001-11-13 by erik_magrini@Baxter.com
No problem. Seems to happen most if I've got Cubase (5.1 r1) running, or just closed it out BTW.
rEalm
Scott Ruda
11/13/01 02:04 AM
Please respond to xl7
To: xl7@yahoogroups.com
cc:
Subject: Re: [xl7] Re: Problems with Windows ME and E-Loader
wrote:
>; I ran into this same thing over the weekend (Although I'm using
> fine. Weird!
Scott
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Universal Inkjet Refill Kit $29.95
Refill any ink cartridge for less!
Includes black and color ink.
http://us.click.yahoo.com/r9F0cB/MkNDAA/ySSFAA/pWZylB/TM
on 11/13/01 4:44 AM, erik_magrini@... at erik_magrini@...
>>> fine.  Weird!
> closed it out BTW.
You are bound to have problems if you have two MIDI programs open at the
same time trying to access the same ports. You just can't do that in
Windows, unless you use Hubi's Loopback or some other special software. Is
that what you are doing?
Does E-Loader work reliably for you when don't have any other MIDI programs
running?
Scott
Yeah, I figured that was true, so I closed Cubase, waited a few minutes
and tried it again.  Still didn't work.  If I either run an audio app that
requires the MIDI port, or run E- Laoder once previously, I need to
restart my computer in order to run it again.  Kind of a pain when you
want to upload a file to Cubase to edit a small part for instance and then
downlaod it back into the XL....
realm
programs
running?
Scott
