Anyone had this happen?
2001-11-23 by mikexl7@yahoo.com
In short what I hear in the phones don't match what comes off the
mains.
This is how I have it set up.  I have the mains going out into my
mixer.  Off sub 1 I am running a send return loop to a reverb rack.
And I am using sub3 as a return from my E5000.
when i plug into the phones all is good.  when I plug into the mixer
All the sounds off the E5000 are in mono and are too quite in the mix.
I just don't get it.  I guess I can just go off the phones out but
that just seems stupid.  Also It would be best to have the phones for
a moniter in a club.
Anyone have any idea of what is going on?
Peace
Mike
Re: Anyone had this happen?
2001-11-24 by heretik7@hotmail.com
Mike,
Just as the Ensoniq ASR-X, the outputs on the MP/XL are quite a bit
hotter than the usual devices...you will also notice that the XL?MP
is quite full of really potentially dangerous to monitor sound
artifacts such as pops and clips.  Turn the volume to 3/4 the way on
when sending this things output signal to anything in your rig.  As
far as the internal sound being different from what comes out the
main out jacks; yes, there is a difference, the output is seemingly
EQ'd in a grungy undesirable way, heavy almost muddy lows with
degraded highs...hmmm, but let's not forget headphones and speakers
are and will always be indisputably different in frequency handling,
and depending on stereo placement of speakers the stereo will not be
rendered quite as well as having a set of cans placed directly over
each ear.  Hope this helps somewhat.
TIK777
Re: [xl7] Re: Anyone had this happen?
2001-11-24 by Colin Owens
TIK777, Mike
I've noticed the XL7 clicking and popping even when I
run certain phrases from certain sounds through a
preamp that can handle some serious gain. I'm
hazarding a guess that the mains preamp on the XL7
can't handle the sound. Turning down the main volume
does take care of this. Better too hot a sound than
have the life compressed out of it.
Do You Yahoo!?
Yahoo! GeoCities - quick and easy web site hosting, just $8.95/month.
http://geocities.yahoo.com/ps/info1
2001-11-24 by mikexl7@yahoo.com
TIK777
Thanks for the reply.
Yes it is a hot box but that is not what I am talking about here.
I am listening through hedphones straight off my mixer and I am using
a Mackie so it seems to handle the heat just fine.
What is happening is the sound that comes off the E5000 (that is
running in as a return)are all in mono.  And the fx are different
from the XL as well.
I totaly don't get it.  I am not talking about a subtle sonic
difference I am saying it is like i am running off a FX send or
sompthing
--- In xl7@y..., heretik7@h... wrote:
> Mike,
on
handling,
be
> TIK777
2001-11-26 by erik_magrini@Baxter.com
Yeah same here, got the clicking and popping this weekend too.  I thought
it was my sound card at first, surprised the XL can't handle it's own
output.
rEalm
I've noticed the XL7 clicking and popping even when I run certain phrases
from certain sounds through a preamp that can handle some serious gain.
I'm hazarding a guess that the mains preamp on the XL7 can't handle the
sound.
Are you using TRS cables (stereo) or ordinary 1/4" patch cords (mono)?
rEalm
2001-11-27 by mikexl7@yahoo.com
I am using stereo cables......Hmmmmmmmmmmm I will try switching to
mono cables and see what happens.
Thanks for the thought rEalm I had not thought of that.
Peace
(mono)?
> rEalm
I tried switching the main outputs to mono pach cords and still the
same thing.
Just don't get it.
Re: [xl7] Anyone had this happen?
2001-11-27 by erik_magrini@Baxter.com
You're just trying to use the sub outs with an external effects
processor/sound module right?  And your return signal is always mono?
The only other thing I would do, is make sure your TRS cords are set up to
transmit stereo the same way teh XL-7 is.  It should be fairly standard I
would think, but some manufaturers might make the differences in which
part of the plug carries left and right channel information.  Actually
looking at page 19 in the manual, it looks like you don't need TRS cord,
but just regular patch cords.  The Tip is the send, and the Ring is the
return.  My guess is that your external gear isn't set up this way :)  You
might need to make special cords to interface with your other gear because
of this, since most gear uses the Ring as ground.  Kind of surprising that
this isn't mention in the manual actually.  Maybe one of those special
Insert Y-cables made by Hosa and the like for Mixer Insert channels would
do the trick?  Let me know if you need help tracking one down...
rEalm
same thing.
Just don't get it.
