Re: [xl7] NEW BUYER WITH A FEW MISC QUESTIONS
2003-05-05 by erik_magrini@Baxter.com
ques #1:Does it require that you have a midi interface to use the command station? or its jus required if you are using the computer as a sequencer? >>>The XX-7's are completely standalone units, so you don't need a midi interface unless you are sequencing froma computer sequencer, or if you need to update the OS. <<< ques #2: why is it that the instructions for the E-loader only show images of Mac OS and not a Windows based system? its not helping me b'cuz I have a windows is there an alternate version? >>>E-Loader will work with Windows systems just fine. In fact it works better with Windows systems that it does Mac systems, as the Mac USB drivers were never released. <<<< ques #3: I was tryin to understand whut exactly the E-loader does..Does it Save SMF only or does it save both Presets and SMF? >>>Yes, saves your pattern and song data, which is essentially SMF plus some set up data as well. Unfortunately, E-Loader does not support Preset loading and saving, and likely never will (this sucks ass, I admit). You can still back up your presets to the PC via sysex dumps to a software sequencer though. <<< ques #4: When I want to save my performance does XL-1/E-loader save in real time to my computer or is it saving to tha command station memory until I upload my saves to my computer? >>>It will save to the Command Station first always. <<< ques #5: How do I assign my own preset drum kit to the pads? is it possible? or do I have to use a kit and its sounds "as is"? I currently have an MPC2000xl and Im accustomed to assigning tha drums myself. >>>Well, you can only use the kits as is in terms of the samples assigned to them (is, you can't pick the drum samples you liek the most and make you're own kits). There's numerous work arounds though, since you can link more than one preset. Do a search in the list archives, plenty of info on this from others. ,<< rEalm [Non-text portions of this message have been removed]
