I did some looking around and it has to do with realtime recording
mixed with quantizing. It's quite annoying, since I like using the
quantize feature to improve the accuracy of my keystrokes, and would
like to see it addressed in the future. It's actually the only
annoyance I've found so far with this wonderful machine :)
/.j
--- In xl7@yahoogroups.com, "glennjamison" <glennjamison@h...> wrote:
> Two problems here that I have also experienced. One is the note
> sticking when you don't it hard enough or maybe hit two notes too
> quickly together. Quite frustrating and I don't know if E-mu has
> addressed it.
> The other happens when a note doesn't cut off at the end of a
pattern
> (or it's something like that). This one has been addressed and
isn't
> supposed to happen anymore in version 2.0. You can see this
problem
> in the bugs fixed list for v2.0 software.
> I'm hoping that they do fix the problem where the note off event
> doens't seem to trigger when the pad is hit too softly or twice
too
> fast. If it has been fixed or if something is being done about it
> it'd be great to know.
> Glenn
> --- In xl7@yahoogroups.com, "Jacob Talkington" <anomaly10@h...>
wrote:
> > Found something else that makes it happen pretty often - when
> > playing sounds via the rubber keyboads, hitting a second note
while
> > I'm already holding one sometimes makes one of them 'stick'.
> > Still baffled.
> > /.j
> > wrote:
> > > Since last night I've repeatedly run into an annoying issue
> > where
> > > one note sticks on until a seemingly random point. Has anyone
> else
> > > come across this or know a fix for it? It appears to happen
most
> > in
> > > Realtime recorded patterns with synths of any sort, and its
even
> > > more likely to happen after I've messed with transposing the
> > pattern
> > > in pattern edit mode, even if I don't save the changes.
> > > Thanks in advance,
> > > /.jacob
