Big Problem
Big Problem
2003-06-01 by digilab
Hello from Greece
  My name is Manos Karadabanis and i have XL-7
  If XL-7 runs in master midi clock mode and sends clock to RS7000-Virus-AN200-P.C-Xv-88,RM1x,Supernova
 Everything runs OK
 If XL-7 runs in slave midi clock mode and receive midi clock from anyone of the other synths or P.C or sequencers
 then i have o problem, XL-7 cannot sync with the other machines.
Also E-loader 1.0 and E-Loader 1.10   cannot work with USB
Because my P.C cannot recognized the USB driver, i tried everything
Manual driver update, safe mode install-uninstall everything
And with midi only connection i can see my banks nut i can't download it to my P.C or download a new operate system to
XL-7.
Re: Big Problem
2003-06-01 by honkeyhindu
would like to help but a little more details would be cool
1) what happens when you put the xl as slave. Does it run slower or
not at all. Can you see a tempo setting when you run it as slave ?
2) when you put it as slave what are you using to send midi clock
as far as the emu web site is concerned they are not taking off the
statement that usb drivers are still giving problems. It could be
that their web admin is a little slack but who is to say.
when you try and update your os do you get an error. What are the
steps taht you take before trying to update your os.
if you go to the FAQ in the file section there is a step by step
guide under general on how to do this
when you use the eloader to see the bank what happens when you right
click on it ( the auctual bank name )?
peace
 In xl7@yahoogroups.com, "digilab" <digilab@o...> wrote:
> Hello from Greece
>  Everything runs OK
> XL-7.
