Re: [xl7] Re:PRESET QUESTION
2003-06-06 by erik_magrini@Baxter.com
I think you need to have PC turned on for all channels in order for them to know what Presets they should be playing. rEalm I know I had program change off on the channel with the problem but I turned it on and that helped but things still seem to be acting weird. I seem to get occasional hiccups, added sounds when patterns change, presets sounding different from day to day. how can any one rely on this thing live???? I hope it is just a matter of my own ignorance and not the MP7 itself. I do name my presets to avoid messing them up. what is everything I need to consider to make sure my MP7 remains stable (right now it seems any thing but reliable) and to avoid messing up the wok & presets that I have been working on. It seems lately that I can't effectively save or even scroll through screens while playing. acopolis > Message: 9 > Date: Thu, 05 Jun 2003 04:03:32 -0000 > From: "justinkoller" <justinkoller@...> > Subject: WinXP & USB Problem > > I've seen some people post about this, but haven't seen a solution > or heard of one working. > > When i turn on the XL7, let it boot up, and THEN plug it into > windows (as the directions say), windows xp will NOT correctly > detect the device. Via MIDI, I have already upgraded to 2.0, and > can run eloader. Eloader was not running while I tried to plug in > the device to USB. > > Emu support has some canned response they used on me twice that > includes "USB is only for sequence back up" and "please read the > instructions and follow them exactly or you'll need to douse your PC > in bleach and reinstall windows". So I'm turning to you guys. > > I've tried this on several PC's (all, unfortunately, run winXP). > Every one complains that an "unknown device" was plugged in, and may > have malfunctioned. Manual installs fail, because windows complains > the drivers I try to set (tried both usb0 and usb1 first) an > incompatible with the device..I'm guessing that's because > it's "unknown". > > But, I'm thinking that the device has some unique ID, (since > subsequent install attempts happen so much faster than the first) > and that I can edit the registry settings for it, so windows can > match up the same strings that exist in the driver vs. what's > detected. > > A.) Anybody got another solution? > b.) What, EXACTLY, does windows XP detect the device as? > > thanx > -jk* > > > > ________________________________________________________________________ > ________________________________________________________________________ --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.487 / Virus Database: 286 - Release Date: 6/1/03 To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
