--- In xl7@yahoogroups.com, "robotchas" <robotchas@y...> wrote:
> --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
> wrote:
> > The E-Mu has remote control capabilities via sysex.
> > Unfortunately, it does not appear to be complete (unless I'm
> > mistaken).
> > Via sysex, for example, you can switch the bank of 16 buttons
> > between Track and Trigger Mode. In track mode, you can turn
> > tracks 4 and 8 on and off remotely.
> Can you elaborate on this? There's no info on this in either the
> XL-7 manual or the P2K sysex spec, as far as I've seen, and I've
> been asking about this kind of thing for a while...
> Remote control muting is good. Does this mean you can control
> Direct Pattern Access via sysex?
I'd be happy to talk sysex. Perhap we should take this discussion to
IBGEEEK due to the estoteric nature oif the topic.
Briefly, take a look at the sysex manual. The latest version I've
seen is 2.2. (I have a good feeling E-Mu might be evolving sysex. At
least I hope they are.) I believe version 2, 2.1 and 2.2 all
discussion remote control via sysex.
In a nutshell, you open an close remote control mode. I suspect it
was designed for the possibility of a software GUI. You have control
over many things, including cursor, data knob, etc. I see it more
for set up than performance. If you open a session, sysex commands
get outputted when you turn knobs--including the master volume. I
have found that between 0 and 127, the master volume knob is unstable
(at least on my CS) and continually gives off sysex volume commands.
So far, I have found that only tracks 4 and 8 can be turned off and
on via remote control. Other buttons are more consistent.
Again, I'd be happy to talk sysex more. I suggest IBGEEK because its
rather technical. (BTW, I've been using an old version of Cakewalk
Professional to get into E-Mu sysex.)
Dr. Steve
