Any one know how to do "matrix" phone effect?......
2003-07-22 by Rob Blue
Im trying to figure out how to do this effect that sounds like...Neo
when he is transfered to the real world through the phone in the
matrix, or similar, BT's signature "machine gun" roll beat.
If any one knows what Im talking about, Thanks!
Re: Any one know how to do "matrix" phone effect?......
2003-07-22 by zerocrossing2001
I can get that exact effect using a KAOSS pad.  I'm not sure which patch, but one of
the delays does it.  Basically it samples makes a loop and then shortens the loop to
the point where it's so short it's starting to get it's own tonality.
I've also seen demos of some of the Korg ETribe units that do a similar thing... I'm not
sure which one does it but it was easy to find on Korg's website under etribe stuff.
BTW, the KAOSS pad II rocks IMO.  I've got one in the effects loop of the XL-7 at all
times.
Mark Sottilaro
--- In xl7@yahoogroups.com, "zerocrossing2001" <zerocrossing2001@y...> wrote:
> > matrix,
Oh, BTW.  The Protozoa ROM has a great Waterphone sample that will also get you
the "I'm touching the mirror and it's melting into me." sound
Mark Sottilaro
Re: [xl7] Any one know how to do "matrix" phone effect?......
2003-07-22 by erik_magrini@Baxter.com
matrix,
>>>There's a few ways you can do this.  My first choice would be to use a
plug in like Waldorf's D-Pole.  This lets you change the sample rate of
audio playing through it in real-time, so you can slowly start to lower it
as the sound plays.  Another way would be ot use something like Crusher-X,
another plug in.
>>>Simple, just take your drum hit and slice it up into 1/32t or 1/64t
slices and repeated them.  BTW, those are triplet slices, for some reason
at small note lengths like these, triplets sound smoother than straight
notes.  I admittedly use this trick ALL the time.  Check out "Void Shaper"
or "Miasma" on my website (http://rEalm.iuma.com) for examples. <<<
rEalm
