E-loader problems
E-loader problems
2003-07-22 by r3gu
I'm using Windows 2000 and the MP7 is connected througt Edirol UM-1
to computer (Midi IN and A OUT).
e-loader recognizes the mp7 if i test it, midi monitor gets messages
from it, and it "sees" all the patterns in MP7..but, when i try to
save my patterns, it thinks for a sec and then tells that "there was
an error..blahblah"... what could be the problem? and how do i use
the USB-connection?, when i insert it, it sees USB composite device
and asks for a driver (which should'nt be needed?) and then takes the
device out of current configuration because the driver does not
exist...
if i remember correctly, i did get them out using Win98 SE..
does any1 else use win2000 with e-loader?
