Yamaha CS80 group photo
Yamaha CS80
Index last updated: 2026-04-28 23:44 UTC
Desoldering Double Sided Question...!?
2009-02-16 by Quazimodo
Hi guys,
Wonder if amyone here could give me a bit of avsice. I am trying to
desolder a 14pin IC from a double sided board.
It's not easy - what is the scret?
I have a spring loaded solder-sucker and can get the solder from the
'usual' side, but the thing is still solid.
How does one 'suck solder' from 'under' the chip...??
Tom
Re: [yamahacs80] Desoldering Double Sided Question...!?
2009-02-16 by rj krohn
using a hakko 808 desoldering gun, you can just wiggle each leg slightly
once the solder is liquified. its so easy. do an entire 16 pin double sided IC in about
15-20 seconds, and you visibly see that the points are clean. i know buying another 3-400 dollar part might seem silly/superfluous, but i would honestly rather dump a synth before dumping that thing. SO useful.-rj
--- On Mon, 2/16/09, Quazimodo <noddyspuncture@...> wrote:
Subject: [yamahacs80] Desoldering Double Sided Question...!?
To: yamahacs80@yahoogroups.com
Date: Monday, February 16, 2009, 7:20 AM
            Hi guys,
Tom
2009-02-16 by David Rogoff
Quazimodo wrote:
> Hi guys,
Tom,
For most double-side PCBs, this shouldn't be a problem with a
solder-sucker. A somewhat counter-intuitive trick is to first add more
solder to the pin/pad. Then heat it up well can remove the solder.
Sometimes it may still stick a little. If you're not trying to save the
chip, just cut the leads off and pull them out with pliers as you apply
a little heat.  If it's a power pin and there's a huge power plane on
the board it can be a pain since all the copper will suck the heat away.
 David
