TC4051P
2010-01-02 by system_700
Index last updated: 2026-04-28 23:44 UTC
Does anyone know if this Mouser part is compatible with the original Toshiba TC4051P IC used in the TSB boards 1 and 2? http://www.mouser.com/Search/ProductDetail.aspx?R=74HCT4051N%2c112virtualkey66800000virtualkey771-74HCT4051N
2010-01-02 by JH.
No. Voltage rating is too low. JH.
----- Original Message ----- From: "system_700" <voyetra8@...> To: <yamahacs80@yahoogroups.com> Sent: Saturday, January 02, 2010 4:34 PM Subject: [yamahacs80] TC4051P Does anyone know if this Mouser part is compatible with the original Toshiba TC4051P IC used in the TSB boards 1 and 2? http://www.mouser.com/Search/ProductDetail.aspx?R=74HCT4051N%2c112virtualkey66800000virtualkey771-74HCT4051N ------------------------------------ Yahoo! Groups Links
2010-01-02 by Jeff Wilkerson
Try this cross reference search engine from NTE http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search?OpenForm I use it sometimes to find an interchange\match.of ic's. but most important its best to compare DATA SHEETS between specific ic's --- On Sat, 1/2/10, JH. <jhaible@...> wrote:
Subject: Re: [yamahacs80] TC4051P
To: yamahacs80@yahoogroups.com
Date: Saturday, January 2, 2010, 4:34 PM
JH.
To: <yamahacs80@yahoogro ups.com>
http://www.mouser. com/Search/ ProductDetail. aspx?R=74HCT4051 N%2c112virtualke y66800000virtual key771-74HCT4051 N
Yahoo! Groups Links
[Non-text portions of this message have been removed]2010-01-03 by kent spong
Hiya No, this is a TTL IC. You want a CMOS one MC1451 or any 4051 CMOS 4000 > To: yamahacs80@yahoogroups.com > From: voyetra8@... > Date: Sat, 2 Jan 2010 15:34:02 +0000 > Subject: [yamahacs80] TC4051P > > Does anyone know if this Mouser part is compatible with the original Toshiba TC4051P IC used in the TSB boards 1 and 2? > > http://www.mouser.com/Search/ProductDetail.aspx?R=74HCT4051N%2c112virtualkey66800000virtualkey771-74HCT4051N > > > > ------------------------------------ > > Yahoo! Groups Links > > > _________________________________________________________________ Add your Gmail and Yahoo! Mail email accounts into Hotmail - it's easy http://clk.atdmt.com/UKM/go/186394592/direct/01/ [Non-text portions of this message have been removed]
2010-01-03 by JH.
> No, this is a TTL IC. Not quite. It *is* a CMOS chip, but made in a technology with smaller structures which only allows lower supply voltage than the old 4000 series, and with TTL compatible thresholds. 74HC stands for "high speed CMOS", and 74HCT stands for "high speed CMOS, TTL compatible". *Not* compatatible with the old 4000 series, as we all agee. JH. > To: yamahacs80@yahoogroups.com > From: voyetra8@... > Date: Sat, 2 Jan 2010 15:34:02 +0000 > Subject: [yamahacs80] TC4051P > > Does anyone know if this Mouser part is compatible with the original Toshiba TC4051P IC used in the TSB boards 1 and 2? > > http://www.mouser.com/Search/ProductDetail.aspx?R=74HCT4051N%2c112virtualkey66800000virtualkey771-74HCT4051N > > > > ------------------------------------ > > Yahoo! Groups Links > > > _________________________________________________________________ Add your Gmail and Yahoo! Mail email accounts into Hotmail - it's easy http://clk.atdmt.com/UKM/go/186394592/direct/01/ [Non-text portions of this message have been removed] ------------------------------------ Yahoo! Groups Links
