Yamaha CS80 group photo
Yamaha CS80
Index last updated: 2026-04-28 23:44 UTC
[yamahacs80] IC m51623p ???
2011-10-24 by papinje
Hi all,
after completing (9 months work...) the overhauling of the CS80, that  is amazingly playing now, I have opened a friends' CS60, that doesn't work (as usual... :-)
I am surprised for finding in all of the the M-voice boards two ICs, named m51623p  and m51628p, instead of the IC8 and IC9  IG00153 and IG00158...
Is this normal?   BTW, no sign of desoldering. All of the traces are immaculate.
The machine is pristine, and only two voice seem to play some sounds...
If they are correct (a newer  or elder series?) is  any modification needed?
Thanks
Fernando
Re: IC m51623p ???
2011-10-25 by Rainer
According to this site, it appears to be the same part number:
http://www.wdgreenhill.com/manu/yamaha_s.htm
--- In yamahacs80@yahoogroups.com, "papinje" <fernandozarone@...> wrote:
> Hi all,
> Thanks
> Fernando
Re: IC m51623p ???
Regarding the voices not playing: check the contacts and conduction of all the (very thin...) wires running to the voice boards, if one them is faulty the entire voice might not sound anymore. I had it on my CS60; we could see that the KAS actually assigned a voice to play, but  one of the voices didn't sound. One of the wires had a bad solder contact...
It's of tremendous help if you have one of these 'indicator' boards in your CS, that shows which voice is (or should be) playing:
http://groups.yahoo.com/group/yamahacs80/photos/album/35984432/pic/list
Hope you'll find the problem!
Rainer
> --- In yamahacs80@yahoogroups.com, "papinje" <fernandozarone@> wrote:
> > Hi all,
> > Thanks
> > Fernando
Re: IC m51623p ???
2011-10-25 by Quazimodo
And you try buying one off them... these guys advertise as if they have everything. Then, when you try getting one off them they say they will have to "order one in"... maybe a year down the line (after you've chased and chased them - they won't contact you!) they then tell you it's unavailabe!
I don't know why they still keep people hopes up by putting those part numbers on their site. Very annoying...;c(
> > Hi all,
> > Thanks
> > Fernando
Re: IC m51623p ???
That's what I suspected indeed. I just used the site to point out that at least those people indicate that the TS's part numbers should be the same as the IG..... ones :-)
If anyone should ever replace a VCO IC, make sure its "Rank" is within the tolerance limits described by Yamaha! otherwise the difference in temperature response will lead them to behave differently amongst each voice, so you can never tune your CS as close as otherwise would be possible.
http://www.cs80.com/docs/service_bulletin/cs-80_service_news_3.gif
http://www.cs80.com/docs/service_bulletin/cs-80_service_news_4.gif
RE: [yamahacs80] IC m51623p ???
2011-10-25 by John Leimseider
Has anyone seen any failures of the "newer" unranked oscillators? I haven't, so far.
John Leimseider
Electronics Technician/ Technicien des instruments électroniques
Cantos Music Foundation/National Music Centre Project/Projet du Centre National de Musique
Second Floor, 134 - 11 Ave SE, Calgary AB T2G 0X5
Phone/ Téléphone: (403) 543-5127
Fax/ Télécopie: (403) 543-5129
www.cantos.ca/www.nmc.ca <http://www.cantos.ca/www.nmc.ca>
Coming up at Cantos
October 30 - All That Jazz Brunch at Thomsons Restaurant
A new jazz series at the Hyatt Regency Calgary.  Enjoy a variety of dynamic jazz perfomances the last Sunday of the month for the All That Jazz Brunch.  Aimee-Jo Benoit performs at Thomsons Restaurant.  11:00am.
October 31 - Blue Mondays All Ages Blues Jam Halloween
Join the Cantos House Band with a special guest for this all ages blues jam. Bring your instruments, bring your blues, bring your appetite and bring your kids to this all ages event the last Monday of every month. All ages and levels of ability welcome! Blue Mondays with special guest Kirby Sewell.  Let's do the monster mash!
Hear that? The National Music Centre will give Canada a place that amplifies the love, the sharing and the understanding of music at the historic King Edward Hotel in the heart of downtown Calgary's revitalized East Village.  The final NMC renderings have been revealed. Play your part and view the building renderings at http://www.nmc.ca <http://www.nmc.ca>
From: yamahacs80@yahoogroups.com [mailto:yamahacs80@yahoogroups.com] On Behalf Of Fernando Zarone
Sent: Tuesday, October 25, 2011 9:08 AM
To: yamahacs80@yahoogroups.com
Subject: Re: [yamahacs80] IC m51623p ???
Thanks, friends,
yes, the ICs are the same; and they work, as seen on the oscilloscope at their outputs, so, fortunately, it could be a wire problem...
I'll let you know what happens...
Yahoo! Groups Links
2011-10-25 by Fernando Zarone
Thanks, friends,
yes, the ICs are the same; and they work, as seen on the oscilloscope at their outputs, so, fortunately, it could be a wire problem�
Re: IC m51623p ???
I don't think we have the luxury of choosing and fine tuning the IG Osc IC's any more - or do we...? I always thought you'd go with the IC you managed to source and put up with it. It's not as though we have an abundance of choice and can be picky... or am I missing something...;c)
Cheerz,
TOM
Re: [yamahacs80] Re: IC m51623p ???
2011-10-25 by jkjelec@comcast.net
I was thinking the same thing.  It s eems to me tha t this means it is even more important to focus on tuning the instrument when it's in it s warm, working state.  And later, during use, be prepared for it to s ound REALLY wonky when its first turned on, and twenty minutes later there will be  pure polyphonic lushness.
jkjelec
"I don't think we have the luxury of choosing and fine tuning the IG Osc IC's any more - or do we...? I always thought you'd go with the IC you managed to source and put up with it. It's not as though we have an abundance of choice and can be picky... or am I missing something...;c)
Cheerz,
TOM"
Yes, the M5162*p  ICs work as well as the corresponding IG****.
I don't know whether this is a last rev of the machine, but it is from the factory for sure.  No sign of any  soldering...
Now, the CS 60 (great condition) only plays the voice n.1 and the voice n. 8.  Fortunately, I do have the simple LED device for detecting the triggered voice (thank you, CSers!) . In the M boards the oscilloscope shows the presence of the right waveforms, but from the VCA IC 4 stage to the output O.  I mean, it seems to be a common problem of those voices, not related to the individual boards!
Any suggestion from the CS gurus?
All the best
Fernando
Re: IC m51623p ???
2011-10-26 by synthparts
The Yamaha IG chips were made by Mistubishi. The Mxxxx is the Mitsubishi part #. I've never seen the 153s just labeled with just the Mits part but almost all the 150s I have are. Are bad voices getting their key gates from the assigner?
Doug
synthparts.com
--- In yamahacs80@yahoogroups.com, Fernando Zarone <fernandozarone@...> wrote:
> All the best
> Fernando
2011-10-26 by Fernando Zarone
Yes,
from KAS trigger points the voltage goes from positive to negative for each voice, the LEDS in the detector device light up regularly
> Doug
> synthparts.com
> > All the best
> > Fernando
