Ring vs. Balanced Modulation
2008-12-29 by derwskee
Looking at the new 285e I am not sure I know the sonic difference between Ring Mod and Balanced Mod...I know what Ring Mod does. Also curious of the internal vs external reference functions: when set ot Internal does this provide an internal Modulator signal that can itself be FM/CV modulated or is this simply the wrong question to be asking...thanks.
2008-12-29 by JB
AFAIK a ring modulator the simple passive circuit with a ring of diodes and transformers and a balanced modulator is an active circuit producing the same result at a far better signal to noise ratio often referred to as a ring modulator as well. The effect is the same in both cases. 285e has an internal sine modulator that can be replaced with an externally applied modulator. The internal modulator can be frequency modulated and controlled by CV. 2008/12/29 derwskee <synpro@aol.com>:
> Looking at the new 285e I am not sure I know the sonic difference > between Ring Mod and Balanced Mod...I know what Ring Mod does. Also > curious of the internal vs external reference functions: when set ot > Internal does this provide an internal Modulator signal that can itself > be FM/CV modulated or is this simply the wrong question to be > asking...thanks. > > > ------------------------------------ > > Yahoo! Groups Links > > > >
The reason for the question came from the descriptive text on the 285e page as follows..."A separate output is dedicated to classic ring modulation, a subset of balanced modulation." If they were identical this statement would not have much point....I guess, maybe.... --- In 200e@yahoogroups.com, Chris Muir <cbm@...> wrote: > > > On Dec 29, 2008, at 9:13 AM, derwskee wrote: > > > Looking at the new 285e I am not sure I know the sonic difference > > between Ring Mod and Balanced Mod...I know what Ring Mod does. > > > I had always considered the terms Balanced Modulator and Ring > Modulator synonyms, myself. I thought that this referred to circuits > that created sum and difference tones, while suppressing the carrier & > modulator, as opposed to AM where the carrier is still present. > > The 261e AM section goes from AM into ring modulation, so I imagine > that the 285e circuit does something similar > > > Also > > curious of the internal vs external reference functions: when set ot > > Internal does this provide an internal Modulator signal that can > > itself > > be FM/CV modulated... > > > Yes, there is an internal oscillator (actually two: one for the freq > shifter and one for the balanced mod section), which can be pitched
> around and FMed. > > - C > > Chris Muir > cbm@... > http://www.xfade.com >
2008-12-29 by Chris Muir
On Dec 29, 2008, at 9:13 AM, derwskee wrote: > Looking at the new 285e I am not sure I know the sonic difference > between Ring Mod and Balanced Mod...I know what Ring Mod does. > I had always considered the terms Balanced Modulator and Ring Modulator synonyms, myself. I thought that this referred to circuits that created sum and difference tones, while suppressing the carrier & modulator, as opposed to AM where the carrier is still present. The 261e AM section goes from AM into ring modulation, so I imagine that the 285e circuit does something similar > Also > curious of the internal vs external reference functions: when set ot > Internal does this provide an internal Modulator signal that can > itself > be FM/CV modulated... > Yes, there is an internal oscillator (actually two: one for the freq shifter and one for the balanced mod section), which can be pitched around and FMed. - C Chris Muir cbm@well.com http://www.xfade.com
2008-12-31 by kkonkkrete
I'd be interested in the definitive answer to this too. My guess is that it allows you to vary continuously from DC-coupled to AC-coupled modulation, with varies the extent to which the carrier frequency is suppressed (i.e. difference between AM and classic 'ring modulation' which has only the sidebands). But this is just a guess! --- In 200e@yahoogroups.com, "derwskee" <synpro@...> wrote:
> > The reason for the question came from the descriptive text on the > 285e page as follows..."A separate output is dedicated to classic > ring modulation, a subset of balanced modulation." If they were > identical this statement would not have much point....I guess, > maybe.... > > > > --- In 200e@yahoogroups.com, Chris Muir <cbm@> wrote: > > > > > > On Dec 29, 2008, at 9:13 AM, derwskee wrote: > > > > > Looking at the new 285e I am not sure I know the sonic difference > > > between Ring Mod and Balanced Mod...I know what Ring Mod does. > > > > > I had always considered the terms Balanced Modulator and Ring > > Modulator synonyms, myself. I thought that this referred to > circuits > > that created sum and difference tones, while suppressing the > carrier & > > modulator, as opposed to AM where the carrier is still present. > > > > The 261e AM section goes from AM into ring modulation, so I > imagine > > that the 285e circuit does something similar > > > > > Also > > > curious of the internal vs external reference functions: when set > ot > > > Internal does this provide an internal Modulator signal that can > > > itself > > > be FM/CV modulated... > > > > > Yes, there is an internal oscillator (actually two: one for the > freq > > shifter and one for the balanced mod section), which can be > pitched > > around and FMed. > > > > - C > > > > Chris Muir > > cbm@ > > http://www.xfade.com > > >
