Re: Ring vs. Balanced Modulation
2008-12-31 by zaum
Reading the website description, clearly a ring modulator is a subset of a balanced modulator's range. Allen Strange discusses it in the context of Audio Rate AM and the original 285 module. "Most balanced modulators must have a manual and/or voltage controlled "modulation" index. If the modulator is designated as completely balanced, the term "index" is irrelevant as index is always at maximum. As discovered with AM, the index controls the magnitude of the sidebands." He mentions the two outputs sets on the original 285, one is VC going from no modulation (zero) to full balanced (ring) and the second is only ring modulation independent of the variable modulation index. "Therefore an instrument labeled "balanced modulator' will provide different degrees of carrier suppression" "With complete balanced modulation there is no need to distinguish between "carrier" and "program". (signal and ref on the Buchla) Also perhaps of interest, though I don't know the if the 285 or 285e is AC coupled, the point is made that without AC coupling any DC offset on an input will add the DC amplitude of the offset frequency to the output (which would have been suppressed had the signal lacked DC offset) nick
