Re: [200e] Mike in
2009-05-05 by ezra buchla
address confusions. what is this "e-mail" ? On Mon, May 4, 2009 at 8:12 PM, ezra buchla <ezra.buchla@gmail.com> wrote: > oops > > > On Mon, May 4, 2009 at 8:12 PM, ezra buchla <ezra.buchla@gmail.com> wrote: > >> i'm not sure what you mean by the "227e mike in" if not the rear XLR jack. >> that is the only input. the two 1/8" jacks on the panel are parallel >> OUTPUTS. >> >> >> On Mon, May 4, 2009 at 8:04 PM, amnesia <amni56@tpg.com.au> wrote: >> >>> >>> >>> HI Ezra >>> >>> Should have the 250e back next week :-) missed it >>> >>> I am inputting the mic into the 227e mike in then the out env follower >>> into a volt/oct...if i try and use the audio out of the mike/env into >>> say channel 4 its really quiet...I havent tried the xlr on the back >>> >>> Ross >>> >>> >>> ezra buchla wrote: >>> > >>> > >>> > hm.... you used the xlr jack on the rear panel? you tried different >>> > settings >>> > of the pre-amp gain (the button)? anything coming out the audio output? >>> > >>> > 261e out -> xlr input should probably come out kinda loud and >>> distorted... >>> > its a lot of gain... >>> > >>> > On Mon, May 4, 2009 at 7:52 PM, cray5656 <amni56@tpg.com.au<amni56%40tpg.com.au> >>> > <mailto:amni56%40tpg.com.au <amni56%2540tpg.com.au>>> wrote: >>> > >>> > > >>> > > >>> > > last night i tried for the first time the MIKE/ MIC in to do some env >>> > > following...all i got was a really quiet signal, I thought that was >>> > strange >>> > > because i did the same thing with my serge and it was really >>> > loud....so then >>> > > i decided to put the output of the 261 into the mic in , and still >>> > it was >>> > > really quiet i pressed the attenuation buttons but no change.....I >>> > am not >>> > > sure if this is normal? >>> > > I am talking the mic in on the 227e >>> > > >>> > > Anyone >>> > > >>> > > Anyone >>> > > >>> > > Bueler >>> > > >>> > > >>> > > >>> > >>> > [Non-text portions of this message have been removed] >>> > >>> > >>> >>> >> >> > [Non-text portions of this message have been removed]
