50g group photo
50g
how do i install and execute a program? but please step by step...
2008-05-23 by tooshorttoremain
i have found many info on the net but neither worked.  i have put the
file on an sd. and then i copy it to the port 2. then i soft reset it (
i press on and f3 together). and it is attached . i got it till now,
but how do i run the program. is there an execute button im missing?
Re: [50g] how do i install and execute a program? but please step by step...
2008-05-23 by Dave Boyd
One thing about the HP-50G: there are a lot of modes and settings and
different ways to do things that will affect how you do things.  I will
assume, for this explanation, that you have set flag 117 to use SOFT
menus instead of CHOOSE menus.  Do that first, please.  (Press MODE,
then F1 to get to FLAGS, then scroll down and make sure that flag 117 is
set to "SOFT menu", then OK and OK.)  Now most (but not all) of the
menus will present themselves on the menu line instead of popping up a
box; you can choose items with one of the top row of keys, the F-keys,
F1 through F6.  There's a lot of useful things this allows you to do,
which the CHOOSE-menus will not allow, which you will find out about later.
How you run the program depends on the particular program and what the
programmer wanted to do.  Some programs attach themselves to the APPS
menu, in which case, press APPS and pick it from the list.  If your does
not appear in the APPS list, it may be a LIBRARY, in which case, press
the orange RIGHT-SHIFT key, then the 2 key, to get to the LIB menu.  Now
the attached libraries will be displayed on the menu line.  Look for the
library you attached.  If you don't see it, press NXT until you do.  If
you find it, press the key for that menu item, and the commands from
that library should be displayed.  Now you can press one of the F-keys
to run the command.  (You may have to have some items on the stack if
the command is a math operation or something like that.)
If you DON'T find it, it's possible the program was not a LIBRARY, which
means it was either a DIRECTORY, or simply a PROGRAM, in which case you
have to do something else; let me know.
Dave Boyd
"If we hit that bullseye, the rest of the dominoes will fall
  like a house of cards. Checkmate."  -Capt. Zapp Brannigan, D.O.O.P.
2008-05-24 by Charles Chindenga
To execute a program on SD card just type
:3:NAME OF PROGRAM
Then press EVAL
- original message -
Subject:	Re: [50g] how do i install and execute a program?  but please step by step...
Date:		23/05/2008 18:36
Dave Boyd
Re: how do i install and execute a program? but please step by step...
2008-06-07 by Brad Pollard
Hello,
This calculator's learning curve is steep... =)
so I am trying to install this program:
http://www.hpcalc.org/details.php?id=4394
the 2KX version has a 'program' file of *.hp
so what do I do?  I tried moving the file from my SD card to the HOME
directory.
so when I go to the Home Directory, I have a "FORMO" button (but
along with several more, inculing 'Start', 'IOPAR', 'PPAR', and then
another directory 'CASDI'.
any ways, pressing FORMO only brings up "Library 1010: FORM..." onto
the stack.
Any ideas about what I'm doing wrong?  I wish there was a awy to
attach small docs to these posts, but if you download the program
there is a nice PDF that details what you should be getting (but I'm
not).
Lastly, is there an easy way to change directories up a level
(without going to the Files buttom)?
thanks guys,
brad
> :3:NAME OF PROGRAM
> Then press EVAL
> From:	Dave Boyd <boydda@...>
reset it (
now,
missing?
and
will
SOFT
MODE,
117 is
up a
keys,
do,
about later.
APPS
does
press
menu.  Now
for the
do.  If
from
keys
if
which
you
> Dave Boyd
D.O.O.P.
2008-06-08 by Tim Wessman
This one is better: http://www.hpcalc.org/details.php?id=6306
> the stack.
It is a library.  Store it in port 2.  Either by using the filer or
typing 2 and pressing STO.  Reboot the calc by pressing and holding
ON-C.  Access using the LIB menu.
UPDIR on the keyboard.
TW
