2002-11-14 by Dr. David A. Perreault
Robert
The programming algorithms from P&Em in, most cases, are configured for
CSBOOT. If it is the same type of flash, you can make a renamed copy of
the algorithm and change the header pasrt of the file to turn off CSBOOT
and turn on CS8. Instructions for doing this are in a file called 32p.doc
If you have problems doing this, log on to P&E's we site
(www.pemicro.com), go to the flash programming algorithms section and do
a request for a programming algorithm file. There is currently no charge
for these algorithms.
Dave Perreault
Robert Yablonski wrote:
>Group,
>I have a 68332 on which I have two flash chips. The first is use for
>boot. It resides at address 0 and is chip selected by CSboot. The second
>resides at address 0 and is selected by CS8. I am using PROG32 to load
>the flash chips. Boot flash load works great. I cannot get PROG32 to
>write to the second flash.
>Is there any help out there.
>Robert E. Yablonski
>To unsubscribe from this group, send an email to:
>68300-unsubscribe@yahoogroups.com
>To learn more about Motorola Microcontrollers, please visit
>http://www.motorola.com/mcu
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
