Index last updated: 2026-04-29 00:01 UTC
Help with Stepper Motor TPU fcn
2003-11-03 by Tim
Hello all,
I have question I hope some can help with.
I am using the Stepper Motor fcn of the TPU on a 68376A (not the G
mask).
My present code, when it gets a command to move the stepper checks to
see if the "desired" and "actual" positions are the same, if so then
set both to the midpoint (0x7FFF). This way it needs some very unusual
commands to cause overflow. Well you guessed it ...
A device we added can send a lot of stepper move commands such that the
"actual" and "desired" don't get reset back to midpoint.
So I can have a situation like:
- the current position is says FF00 and moving in a positive direction
and ending at FFF0 say.
- then I get a command to move another say F0 positive.
- well FFF0 + F0 = 100E0, but the SM fcn uses 16bit registers so this
is 00E0 and hence a large negative move and in-correct behaviour.
What are possible solutions?
- can I take the current position (@ FF00) and the desired position
(@FFF0)(before new request) and set current position to be 8000 and
desired position to be 80F0 and not screw up the movement in process?
- other options?
Tim Flynn
Director of R&D
RMS Welding Systems
Ph.(780)955-3907
http://www.rmsweldingsystems.com
Tim Flynn
Director of R&D
RMS Welding Systems
Ph.(780)955-3907
Re: [68300] Help with Stepper Motor TPU fcn
2003-11-12 by Tim
Charlie,
Are you out there still ?
On Monday, November 3, 2003, at 11:48  AM, Tim wrote:
> Hello all,
> mask).
> - other options?
> Tim Flynn
> Director of R&D
> RMS Welding Systems
> Ph.(780)955-3907
> Tim Flynn
> Director of R&D
> RMS Welding Systems
> Ph.(780)955-3907
> Rent DVDs Online - Over 14,500 titles.
> No Late Fees & Free Shipping.
> Try Netflix for FREE!
> http://us.click.yahoo.com/xlw.sC/XP.FAA/3jkFAA/dN_tlB/TM
> To unsubscribe from this group, send an email to:
> 68300-unsubscribe@yahoogroups.com
> To learn more about Motorola Microcontrollers, please visit
> http://www.motorola.com/mcu
> Your use of Yahoo! Groups is subject to
Tim Flynn
Director of R&D
RMS Welding Systems
Ph.(780)955-3907
