Fwd: [68300] Clock drift
2005-06-10 by Tim
I thought that was a kind a dumb mistake of mine, to have bits wrong. Then I looked at my 68376 documentation. It says that the numbers I was running are OK. So ... everyone should check their SYNCR values. By the way, I've got it running great and I got good CAN numbers too. Better than before. Tim Begin forwarded message: > From: Tim <Tim.Flynn@...> > Date: June 3, 2005 2:22:28 PM MDT (CA) > To: 68300@yahoogroups.com > Subject: Re: [68300] Clock drift > > > Thanks to Charlie! > In my start up code for the clock (SYNCR) I had X bit = 0. A no-no > @ 20.45 MHz. > Changed the SYNCR value as per Charlie's recommendation and the > clock is now stable over temperature. Thanks again Charlie ! > New problem! I have a choice of either 19.92 MHz or 20.97 MHz. > Either breaks my CAN communication. I'm running at 250 kbit/s. and > I need to communicate with SJA1000 CAN devices and 56F803 Freescale > devices. > Anyone with CAN values that they would recommend? > > > > Tim Flynn > RMS Welding Systems > Ph.(780)955-3907 > http://www.rmsweldingsystems.com > [Non-text portions of this message have been removed]
