Index last updated: 2026-04-29 00:01 UTC
Re: [68300] Digest Number 198
2005-06-06 by jhgreen@parker.com
The SJA1000 allows both a programmable prescaler and bit length.  using
20.97MHz, divide by 6 (BRP = 2), and 14 time period; as an example TSEG1=6,
TSEG2=6 puts the read sample point about in the middle.  The actual values
will depend on the characteristics (length and loading) of the bus.
Jerry Green
Parker Hannifin ESD
                      68300@yahoogroups
                      .com                     To:       68300@yahoogroups.com
                                               cc:
                      06/04/2005 07:41         Subject:  [68300] Digest Number 198
                      AM
                      Please respond to
                      68300
There are 2 messages in this issue.
Topics in this digest:
      1. Clock drift
      2. Re: Clock drift
________________________________________________________________________
Message: 1
   Date: Fri, 3 Jun 2005 10:49:18 -0600
Subject: Clock drift
Hello Group ( I hope there are people still out there ),
I have an issue with clock drift with temperature. I have a -20 to
+60C 4.194 MHz crystal on a 68376 design. As I get the temperature up
to about 50 C, I start to see the CLKOUT pin frequency drop. The
normal rate is 20.45 MHz (picked for CAN reasons)
At about 50C clock out is 20.09 MHz , at 60 C -> 19.63 MHz.
This more than +/- 50 ppm spec of the crystal.
I am using a 1.5 K ohm series resistor and 22 pF load caps. I have
tried 27 pF as well.
I am using the high stability VCO filter too.
Anyone have some pointers as to how to correct this?
Tim Flynn
RMS Welding Systems
Ph.(780)955-3907
http://www.rmsweldingsystems.com
Message: 2
   Date: Fri, 3 Jun 2005 14:22:28 -0600
Subject: Re: Clock drift
Thanks to Charlie!
In my start up code for the clock (SYNCR) I had X bit = 0. A no-no @
20.45 MHz.
Changed the SYNCR value as per Charlie's recommendation and the clock
is now stable over temperature. Thanks again Charlie !
New problem! I have a choice of either 19.92 MHz or 20.97 MHz. Either
breaks my CAN communication. I'm running at 250 kbit/s. and I need to
communicate with SJA1000 CAN devices and 56F803 Freescale devices.
Anyone with CAN values that they would recommend?
Tim Flynn
RMS Welding Systems
Ph.(780)955-3907
Yahoo! Groups Links
"PLEASE NOTE: The preceding information may be confidential or privileged.
It only should be used or disseminated for the purpose of conducting
business with Parker. If you are not an intended recipient, please notify
the sender by replying to this message and then delete the information from
your system. Thank you for your cooperation."
