RE: [AN1x] Re: Ribbon Controller lost Config
2002-04-05 by Oeschey, Lars
> Man that IS weird?! indeed ;) especially, since it hit *every* patch. I don't know exactly which patch used the ribbon at all, but usually there is something assigned to it. I flipped through the 40 or so presets (not factory, have some commercial stuff in there), and tried the ribbon, and nothing happened. Yesterday I made a quick check (took the synth with me again, usually it's in the jamroom), and assigned to the patch I use with ribbon some filter parameters, i.e. Ribbon-X -> VCF_cut, and it sounded somewhat like it used to. But not really, before it was the way, that the sound was reset to some default when I took the finger away from the ribbon, now the sound also gets "reset", but to a different (low filter setting) sound :( It seems, just changing the Ribbon-X and Ribbon-Z doesn't give me the same results than before. Seems I gotta check out that backup I gladly made *before* I started fumbling (as I always do, I work in IT and I *know* that bad things happen ;)) Lars
