AVR-Chat
avr programming
avr programming
2012-01-09 by shirin ghanbari
I program the fuse bits of the avr mega under 1.5MHZ external crystal and then i can not program it it . chip enable error
please help me what can i do?
Re: [AVR-Chat] avr programming
2012-01-21 by Zack Widup
What programmer are you using?
Zack
2012-01-21 by shirin ghanbari
paralell programer with LPT port
To: AVR-Chat@yahoogroups.com
Sent: Saturday, 21 January 2012, 19:17
Subject: Re: [AVR-Chat] avr programming
Zack
2012-01-21 by sania safdar
g540 and ISP
Best Regards
Sania Safdar
Sent: Saturday, January 21, 2012 8:47 PM
Zack
ok have parallel port & ISP
To: "AVR-Chat@yahoogroups.com" <AVR-Chat@yahoogroups.com>
Sent: Saturday, 21 January 2012, 19:54
g540 and ISP
Best Regards
Sania Safdar
Zack
2012-01-21 by Jim Wagner
The G540 does NOT work with ISP. You have to remove the mcu from your circuit and put the mcu in the programmer. ISP is "In System Programming" and works with an ISP programmer and your application board.
Further, if you look on the list of supported devices, here:
http://www.pic16.com/soft/G540_DeviceList.txt
There is no Atmel mega or avr chip even listed. It WILL program Atmel programmable logic devices and memory, but no MCU. So, even though the heading to the product says:
G540 USB Universal Programmer for EPROM FLASH GAL AVR PIC 51
Either that headline is lying or the device list is lying. Based on the list of supported devices, this device is totally useless for any atmel mcu.
Jim Wagner
Oregon Research Electronics
On Jan 21, 2012, at 8:24 AM, sania safdar wrote:
> g540 and ISP
> Best Regards
> Sania Safdar
> From: Zack Widup <w9sz.zack@gmail.com>
> Zack
im nt using ISP with g540 i just have these two options for programing
i hv programed atmega88 dip using g540 but its nt working
Best Regards
Sania Safdar
Sent: Saturday, January 21, 2012 9:39 PM
Jim Wagner
> g540 and ISP
> Best Regards
> Sania Safdar
> Zack
Yahoo! Groups Links
If its not "working", then it is very likely that you have NOT programmed it.
Jim
> Best Regards
> Sania Safdar
> From: Jim Wagner <wagnerj@proaxis.com>
> Jim Wagner
> > g540 and ISP
> > Best Regards
> > Sania Safdar
> > To: AVR-Chat@yahoogroupscom
> > Zack
RE: [AVR-Chat] avr programming
2012-01-22 by Dave McLaughlin
Can you post the fuse settings you are using?
Most of the time the reason an AVR does not work it because the fuse
settings for the osc are wrong. My client had this very issue with a
programmer he purchased.
Check your fuse settings:
Dave...
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of Jim Wagner
Sent: 22 January 2012 05:59
it.
Jim
> Best Regards
> Sania Safdar
2012-01-22 by Jim Wagner
Even more important is to verify whether or not you can read the device signature bytes.
If you cannot, there are several possible reasons:
1) Bad wiring
2) Bad programmer settings
3) Programmer set for too high clock rate compared to MCU clock. Programmer clock must be less than 1/4 the frequency of the MCU clock.
4) Previous fuse setting which no longer gives an operating clock for the MCU.
By far, the last is very common. The usual solution is to add a low frequency external oscillator to drive the X1 pin. That will provide a clock for all of the fuse error settings. Be sure to set the programmer clock to less than 1/4 the frequency of the external clock.
Jim Wagner
> Dave...
> Of Jim Wagner
> it.
> Jim
> > Best Regards
> > Sania Safdar
Re: avr programming
2012-01-23 by muhammad SHABBIR
Dear sania
i have own build isp programmer and using since last 6 years with tiny2313 its good working. also now using with atmega 48 nice working. and now in nov 2011 i bought G540. but not checked on avr som work on eprom with g540 its good.. now tell me in detail. where is the problem. on  tiny 2313 i worked with avr studio and little ave assembler.
shabbir
--- In AVR-Chat@yahoogroups.com, sania safdar <see_wide_sea@...> wrote:
> g540 and ISP
> Â
> Best Regards
> Sania Safdar
>  From: Zack Widup <w9sz.zack@...>
> Â
> Zack
Re: [AVR-Chat] Re: avr programming
2012-01-23 by shirin ghanbari
i programed the fuse bits  with following
ckesl0=1
cksel1=0
sksel2=0
cksel3=1
and then i can not program it because the the program show chip enable error
my programmer is the parallel and have isp port and have socket for mega8 with 6000000MHZ crystal
when i programed it on internal crystal i do not have any problem but in external i have problem  and the programmer can not erase chip or programmed it
Sent: Monday, 23 January 2012, 7:06
Subject: [AVR-Chat] Re: avr programming
Dear sania
shabbir
> g540 and ISP
> Â
> Best Regards
> Sania Safdar
> Â
> Zack
2012-01-23 by wagnerj@proaxis.com
What chip?
Jim Wagner
> ckesl0=1
> cksel1=0
> sksel2=0
> cksel3=1
> error
> programmed it
>  From: muhammad SHABBIR <moghul40@yahoo.com>
> Â
> Dear sania
> shabbir
>> g540 and ISP
>> Best Regards
>> Sania Safdar
>> Zack
>> and
atmega8
Sent: Monday, 23 January 2012, 20:21
Subject: Re: [AVR-Chat] Re: avr programming
What chip?
Jim Wagner
> ckesl0=1
> cksel1=0
> sksel2=0
> cksel3=1
> error
> programmed it
> Â
> Dear sania
> shabbir
>> g540 and ISP
>> Best Regards
>> Sania Safdar
>> Zack
>> and
That setting of CKSEL is for a low frequency crystal. That means 32KHz or so.
To recover your chip, you will either need to hook up a 32KHz crystal or
connect an external clock signal (maybe about 1MHz). Then you can program
it again.
Jim
> atmega8
>  From: "wagnerj@proaxis.com" <wagnerj@proaxis.com>
> Â
> What chip?
> Jim Wagner
>> ckesl0=1
>> cksel1=0
>> sksel2=0
>> cksel3=1
>> error
>> mega8
>> programmed it
>> Dear sania
>> tiny2313
>> g540
>> shabbir
>>> g540 and ISP
>>> Best Regards
>>> Sania Safdar
>>> Zack
>>> and
thanks
i must connect or in programmer board or connect it outside of the programmer with bredboard
Sent: Monday, 23 January 2012, 20:25
it again.
Jim
> atmega8
> Â
> What chip?
> Jim Wagner
>> ckesl0=1
>> cksel1=0
>> sksel2=0
>> cksel3=1
>> error
>> mega8
>> programmed it
>> Dear sania
>> tiny2313
>> g540
>> shabbir
>>> g540 and ISP
>>> Best Regards
>>> Sania Safdar
>>> Zack
>>> and
