On 4/16/2012 6:33 AM, bayramdavies wrote:
> Group,
> In my opinion still, Don Kinzer's posts on where to use the volatile
> qualifier are unassailable and Bob Paddock's disagreement, "Volatile
> is never the solution to a problem with threads", is without merit.
> Read on if you have the stomach for it.
> Bob,
> You write "I stand by what I said." and then write "Volatile always
> needs to be used appropriately, threads or no threads.". This is not
> what you previously wrote. If this is what you wish you had wrote,
> we're done here.
> You write "I fail to see how John [Regehr] and company are wrong".
> They are wrong by counter-example. They propose that "volatile is
> almost useless for multi-threaded programming". It isn't hard to be
> successful in multi-threaded programming design problems using only
> volatile and, to make the point, I provided an example.
> You write "A ISR() changing a value ... to me is not a 'thread'". I
> don't know why you bring this up. The distinction is arbitrary and
> does not help the argument. If you have a mechanism to safely pass
> data to and from interrupt threads, then you can use it between other
> types of execution threads as well, including multi-processor and DMA.
> You quote ISO/IEC 9899:201x. Footnote 134) says one of the things that
> Don says and does not support your argument. You offer no support for
> your *new* argument that "There are places where applying 'volatile'
> blindly will produce code that is broken", although, depending on your
> definition of "broken", I could agree with you or not. Again, this has
> no relevance to your previous argument that "Volatile is never the
> solution to a problem with threads".
> You write "There is more than just adding 'volatile' on a variable or
> register to make bug free code". Of course. Nobody has said otherwise.
> You must also design good algorithms, express them correctly in your
> chosen language, have a reliable compiler, etc, etc.
> You write "So the argument is to blindly apply volatile?". Now your
> post is looking like an attack, because this is certainly not the
> argument. Don has written that the "volatile attribute must be used"
> on certain variables and goes on to explain how to figure out whether
> a variable should be volatile, with examples. So the argument is
> precisely not what you claim it is, rather it is to apply volatile
> with your eyes open.
> You quote ISO/IEC 9899:201x again. Footnote 111 is taken entirely out
> of context. In the paragraph that references the footnote, the
> document states that an assignment expression has a value (which, as
> we know, can be used as an rvalue in another assignment, or as a
> function argument, etc.). It says that the value of the assignment
> expression is what has been stored in the object referenced by the
> left operand, which is kind-of obvious, but has to be said. The
> footnote merely says that if the compiler needs the expression value,
> it can either read back the value of that object or just remember what
> it stored there and carry on. (I would argue that if the object is
> volatile, the specification should pick one or the other and not leave
> this open as the read-back could have side-effects. This is an area
> where the incomplete specification of the language can trip you up,
> but is easily avoided by not using the values of assignment
> expressions when the object referenced by the left operand is volatile.)
> With regard to my "example of passing data between threads of
> execution using *only* the volatile qualifier", you write "Herb Sutter
> covers exactly this example in ...". Well, this is a demonstrably
> false statement. If you read only as far as page 2 of the article, you
> can see that the only thing that my example and the subject of the
> article have in common is the goal of passing data between producer
> and consumer threads. You seem again to be more interested in
> discrediting me that supporting your argument.
> In discussing my example, you write that counter access "must be
> *explicitly* atomic, unless the counters are uint8_t on our 8-Bit
> AVR's". Well, on an 8-bit machine, they would naturally be 8 bits
> because that is the machine word size, so access to an 8-bit object is
> inherently atomic, as I required, and your comment is not helpful. You
> describe the use of integer counters, the fact that the C language
> requires an integer to be at least 16 bits and the consequence that
> access to a 16-bit counter is not inherently atomic on an 8-bit
> machine and so the technique I have described will not work. You are
> correct, but since I never said that it would work unless "counters
> ... [are] of a type such that access ... is inherently atomic" you
> again give the appearance of disagreeing with me without actually
> engaging my argument.
> I'm done here, so, Bob, you may have the last word.
> Graham Davies
> ECROS Technology
> www.ecrostech.com
