AVR-Chat
RE: [AVR-Chat] Unable to view arguments in AVRStudio
2005-04-11 by wbounce
You are using dwarf2 and that is correct. What do you mean they do not
disaply correctly? Are you openning the .elf file. Are you setting the
correct chip and avr simulator? Are you adding a watch statement? What
do they look like?
From: Chuck Hackett [mailto:egroupscdh@WhiteTrout.net]
Sent: Monday, April 11, 2005 2:18 PM
To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] Unable to view arguments in AVRStudio
I'm using AVRStudio 4.10.356 and avr-gcc (GCC) 3.4.3.
I seem to be able to step through code ok but arguments passed into
functions do not (in my mind) display the correct values.  It's as
though AVRStudio is looking in a location that is different from what
the disassembled code indicates.
Below are the results of a make "all" from within Programmer's Notepad.
Can someone tell me what debug format I should be using with AVRStudio
4.10.356?
Chuck Hackett
> "make.exe" all
-------- begin --------
avr-gcc (GCC) 3.4.3
Copyright (C) 2004 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Size before:
easyavr_acix.elf  :
section            size      addr
.text             12008         0
.data               210   8388704
.bss                339   8388914
.noinit               0   8389253
.eeprom               0   8454144
.debug_aranges       20         0
.debug_pubnames    1364         0
.debug_info        2871         0
.debug_abbrev       334         0
.debug_line        4047         0
.debug_str         1220         0
Total             22413
AVR Memory Usage:
Device: atmega16
Program:   12218 bytes (74.6% Full)
(.text + .data + .bootloader)
Data:        549 bytes (53.6% Full)
(.data + .bss + .noinit)
Compiling: easyavr_acix.c
avr-gcc -c -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=8000000UL  -Os
-funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall
-Wstrict-prototypes -Wa,-adhlns=easyavr_acix.lst  -std=gnu99 -MD -MP -MF
.dep/easyavr_acix.o.d easyavr_acix.c -o easyavr_acix.o
Linking: easyavr_acix.elf
avr-gcc -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=8000000UL  -Os
-Wstrict-prototypes -Wa,-adhlns=easyavr_acix.o  -std=gnu99 -MD -MP -MF
.dep/easyavr_acix.elf.d
easyavr_acix.o --output easyavr_acix.elf
-Wl,-Map=easyavr_acix.map,--cref    -lm
Creating load file for Flash: easyavr_acix.hex
avr-objcopy -O ihex -R .eeprom easyavr_acix.elf easyavr_acix.hex
Creating load file for EEPROM: easyavr_acix.eep
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O ihex easyavr_acix.elf easyavr_acix.eep
Creating Extended Listing: easyavr_acix.lss
avr-objdump -h -S easyavr_acix.elf > easyavr_acix.lss
Creating Symbol Table: easyavr_acix.sym
avr-nm -n easyavr_acix.elf > easyavr_acix.sym
Size after:
easyavr_acix.elf  :
section            size      addr
.text             12008         0
.data               210   8388704
.bss                339   8388914
.noinit               0   8389253
.eeprom               0   8454144
.debug_aranges       20         0
.debug_info        2871         0
.debug_abbrev       334         0
.debug_line        4035         0
.debug_str         1220         0
Total             22401
AVR Memory Usage:
Device: atmega16
-------- end --------
> Process Exit Code: 0
Yahoo! Groups Links
2005-04-14 by Chuck Hackett
> From: wbounce [mailto:wbounce@safeplace.net]
> do they look like?
The problem seemed to go away after reloading AVRStudio but I'll have to keep my
eye on it.  I was opening the .elf file and the chip was set correctly.  I'm
using JTAG via Graham's ICE-Cube, not simulation.  No added watch statement,
just inspection when in the function.
As I recall, what I saw was one value reported by AVRStudio when the mouse
hovered over the argument and a different value displayed in the processor
register set for the register that the assembly code showed as holding that
variable.  BTW: the code worked, using the correct value in execution.  It
seemed that only the value reported by AVRStudio was incorrect.
Chuck Hackett
"Good judgment comes from experience, experience comes from bad judgment"
7.5" gauge Union Pacific Northern (4-8-4) 844
http://www.whitetrout.net/Chuck
