AVR-Chat
need variables to be stored in EEPROM
2005-04-25 by arhodes19044
I see in the docs how to use the registers to access the EEPROM on
my ATmega128.
However, Which part of it is allowed to be used?  Is there nothing
in it unless I use it myself?
Does GCC-avr give me tools to allocate variables in eeprom
automatically?  Should I use MALLOC in some manner?  I see some
basic tools in libc to access EEPROM at a very low level.  Are there
some higher level access routines?
I guess I do not really need much in the way of routines.  But it
would be nice to have variables taged in some manner as residing in
EEPROM, then I can read and write to them as normal variables with
the access taken care-of invisibly in the background.
I only have a few variables of various sizes to save, but I may want
to use the rest as a data-logging function, in some sort of circular
buffer.  The circular buffer would be accessed as a big array
structure, probably.
-Tony
Re: need variables to be stored in EEPROM
Actually, that struct idea is just perfect.
I definitely was planning on keeping an SRAM version of the
variables, then only save the requesite info when necessary.
One of these will be a "first-run" flag which will allow
initialization of the EEPROM, then there are some setting and
calibration values to keep.  Most of the time I will have time to
write then verify the data.  Maybe once in a while the writes will
occur during a time-critical period, so those (what is it? 4ms to
write?).  I can not turn off interrupts because there is a 1ms clock
tick interrupt.  Other less important interrupts occur at a MAXIMUM
frequency of every 1.8ms.  And usually those interrupts will be
every 45ms or so!
Anyway, I can not disable interupts, but I can verify at the end.
From the code I saw, I would not have thought that interrupting the
register loading process would be a problem, but maybe it uses that
TEMP register.  I have not looked at the specific doc for the 128
yet.  About to, tho.
Thanks for the ideas.
-Tony
--- In AVR-Chat@yahoogroups.com, Philipp Adelt <p.adelt@w...> wrote:
> Hi Tony,
on
> > my ATmega128.
nothing
> This is correct, you can use each and every byte. There have been
> rumours that the first types of AVR had a problem with "random"
> corruption of the very first EEPROM cell at address 0. Most people
tell
> that Atmel has fixed the problem in newer (mega) devices. Others
say
> that due to the improved startup behavior of newer device types
> (including the advent of the brown-out detector) bad user design
is less
> likely to lead to execution of random commands that could lead to
> corruption of address 0. (Remember that in a brown-out condition,
an AVR
> can easily execute >10million errors per second..)
there
> AFAIK, the avr-libc routines in avr/eeprom.h are as good as it
gets. You
> could write your own macros of course. Remember to respect the
timed
> write requirements from the data sheet (or the avr-libc routines).
This
> includes disabling interrupts or a scheme to re-try writing if you
can't
> afford turning them off.
> Malloc won't be your friend, it will allocate you a heap chunk of
SRAM.
want
circular
> The easy way is to put all your EEPROM variables into a struct,
hold an
> instance of that struct in SRAM and save the entire sizeof(struct)
bytes
> into the EEPROM as a block (avr-libc has a nice function for
that). If
> SRAM is so tight that you can't afford holding a copy of the data
in it,
> this won't help.
> Philipp
Re: [AVR-Chat] need variables to be stored in EEPROM
2005-04-25 by Philipp Adelt
Hi Tony,
> my ATmega128.
corruption of the very first EEPROM cell at address 0. Most people tell
that Atmel has fixed the problem in newer (mega) devices. Others say
(including the advent of the brown-out detector) bad user design is less
corruption of address 0. (Remember that in a brown-out condition, an AVR
AFAIK, the avr-libc routines in avr/eeprom.h are as good as it gets. You
could write your own macros of course. Remember to respect the timed
write requirements from the data sheet (or the avr-libc routines). This
includes disabling interrupts or a scheme to re-try writing if you can't
Malloc won't be your friend, it will allocate you a heap chunk of SRAM.
The easy way is to put all your EEPROM variables into a struct, hold an
instance of that struct in SRAM and save the entire sizeof(struct) bytes
into the EEPROM as a block (avr-libc has a nice function for that). If
SRAM is so tight that you can't afford holding a copy of the data in it,
this won't help.
Philipp
Yes, I can see that the structure will provide a convenient
technique to read & write the entire block.
It has been a long time since I worked with structures.  Is there a
way to get the offset of the element within the structure?
Something like "&structure.element".  This way, I can start with the
location of the structure in SRAM or in EEPROM and then access the
individual element by base + offset.  Will sizeof() work with
structure elements?
I keep forgetting what stuff I used to do was in C++.  Like I was
sure I could pass a variable by reference and then use it as a
regular variable in the called subroutine (instead of dereferencing
by using *var).  Nope that was C++.
I used to get slightly into the object oriented structures, but I
found it more confusing that more simple structures.  I forget if
the dot operator (I seem to remember that is its name) is C++ only.
I obviously have more homework to do.
It is impressive (to me) how fast C is coming back to me considering
I only used it for about 2 years continuously, then 4 years
intermittently, then not at all for the last 12 years.
-Tony
> You can compile the default values of your EEPROM contents into
your
> code by placing them in the .eeprom section. This way the ISP
and/or
> JTAG programmer will write them when the FLASH code is written
during
> production.
> As for the syntax of compiling EEPROM variables all I can say
is, "I've
> done it" but don't have an example under my fingertips or in CVS.
IIRC
> the variables were defined in a .c source file reserved
specifically for
> this purpose. In the Makefile this one source file was compiled
with an
> option to map .data to .eeprom, or some such thing.
> It may be one can tag the variable with an attribute to place it in
> EEPROM.
> One has to be careful with this sort of mapping to EEPROM because
these
> variables can not be reached without special handling, yet appear
to
> have addresses same as any other variable.
> So one might use a typedef to define the struct which is to contain
> EE-backed data. Then use the typedef to allocate one in eeprom and
> another in sram.
> //  in ee_backed.h file place something like this:
> typedef struct {
> 	uint32_t	serial_number;
> 	uint8_t		cal[8];
> } EE_BACKED;
> // in a code file place something like this:
> #include "ee_backed.h"
> EE_BACKED sram_ee;
> // then in a special file just for ee variables:
> uint8_t	im_afraid_to_use_byte_0;
> EE_BACKED ee_ee.
> Then someplace, probably your startup code in main():
> eeprom_read_block( &sram_ee, &ee_ee, sizeof(sram_ee) );
> The whole point is to make the compiler do the work of allocating a
> local copy and of keeping track of where the data was stashed in
eeprom.
> David Kelly N4HHE, dkelly@H...
> Whom computers would destroy, they must first drive mad.
Great!  I do not remember the "offsetof()" function.  I will look it
up right now.  THANKS
-Tony
--- In AVR-Chat@yahoogroups.com, Robert Adsett <subscriptions@a...>
wrote:
a
> >structure elements?
> Look for the standard macro offsetof().  And yes sizeof works with
> structure elements, although depending on the compiler and micro
adding up
> the sizes of the previous elements will not necessarily give the
same
> answer as offsetof (I expect it would on an AVR).
> Robert
> " 'Freedom' has no meaning of itself.  There are always
restrictions,   be
> they legal, genetic, or physical.  If you don't believe me, try to
chew a
> radio signal. "  -- Kelvin Throop, III
> http://www.aeolusdevelopment.com/
Oh yeah.  I remember the pain of figuring when to use the > vs .
operators.  pointer references or whatever.  OUCH!!!  Well, I will
go through it again.
2 reasons.  The structure needed for the initializer variables, then
the data log which is a PERFECT structure application.
so as I remember it will be struct_name>item, but log-array[x].item.
or maybe I have it backward.  I have to check.  Once you get it down
it is nice and easy.  Confusing otherwise.
-Tony
a
> >structure elements?
adding up
same
> Robert
restrictions,   be
chew a
Re: [AVR-Chat] Re: need variables to be stored in EEPROM
2005-04-25 by Dennis Clark
Tony,
   About disabling interrupts during EEPROM writes, see below:
> every 45ms or so!
   You might want to check the data sheet before you think this:
1. Wait until EEWE becomes zero.
2. Write new EEPROM address to EEAR (optional).
3. Write new EEPROM data to EEDR (optional).
4. Write a logical one to the EEMWE bit in EECR.
5. Within four clock cycles after setting EEMWE, write a logical one to
EEWE.
Caution: An interrupt between step 4 and step 5 will make the write
cycle fail, since the
EEPROM Master Write Enable will time-out. If an interrupt routine
accessing the
EEPROM is interrupting another EEPROM access, the EEAR or EEDR Register
will be
modified, causing the interrupted EEPROM access to fail. It is
recommended to have
the Global Interrupt Flag cleared during all the steps to avoid these
problems.
It is a good idea to disable interrupts before writing a byte to EEPROM.
> yet.  About to, tho.
> -Tony
[snip]
DLC
Dennis Clark    TTT Enterprises
2005-04-25 by David Kelly
You can compile the default values of your EEPROM contents into your
code by placing them in the .eeprom section. This way the ISP and/or
JTAG programmer will write them when the FLASH code is written during
production.
As for the syntax of compiling EEPROM variables all I can say is, "I've
done it" but don't have an example under my fingertips or in CVS. IIRC
the variables were defined in a .c source file reserved specifically for
this purpose. In the Makefile this one source file was compiled with an
EEPROM.
One has to be careful with this sort of mapping to EEPROM because these
variables can not be reached without special handling, yet appear to
another in sram.
typedef struct {
	uint8_t		cal[8];
} EE_BACKED;
EE_BACKED sram_ee;
EE_BACKED ee_ee.
local copy and of keeping track of where the data was stashed in eeprom.
David Kelly N4HHE, dkelly@HiWAAY.net
Thanks!  That jump starts my usage of the structures.  You have been
a geat help!
-Tony
> name->item is a pointer dereference (it's a two character operator)
> name.item is simply a non-pointer reference.
> Given
> struct sdf {
>     int a;
>     int b;
> } *ptr, non_ptr;
> You would use
> non_ptr.a = ptr->a;
> Or
> non_ptr.a = (*ptr).a;
> Both lines have the same meaning.  It's not really an array/non-
array type
> of difference although it can show up in that context.
> Of course you should init the pointer to something valid first ;)
> Robert
restrictions,   be
chew a
It was simpler than I remembered. This puts ee_serial_number in EEPROM:
uint32_t ee_serial_number __attribute__ ((section (".eeprom")));
2005-04-25 by Robert Adsett
>structure elements?
structure elements, although depending on the compiler and micro adding up
the sizes of the previous elements will not necessarily give the same
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
Given
struct sdf {
    int a;
    int b;
} *ptr, non_ptr;
You would use
non_ptr.a = ptr->a;
Or
Both lines have the same meaning.  It's not really an array/non-array type
Robert
> structure elements?
Yes, and yes.
But remember if one tries (&structure.element - &structure) pointer
arithmetic may come into play. Make casts to (size_t) before doing the
math. Thats the point of the offsetof() macro mentioned.
#define offsetof(type, field) ((size_t)(&((type *)0)->field))
For the above to work your structure has to be in a typedef.
2005-04-26 by arhodes19044
OK, I got EEPROM writes and reads working with a minimum of fuss.
The macro offsetof() worked beautifully.  I even understood how it
was working!!!!  Amazing.
I found that I had to cast it as a (void*) when I went to use it in
an eeprom_write_block() function.  I even made that long instruction
its own macro.  So, a macro within a macro.  worked the first time.
I could not believe it.   I was sure it was going to write somewhere
off in address space causing a major crash!  It simply worked.
I have nearly completed all the "hard" basic interacting-with-
hardware tasks.  Soon, I will be implementing the interaction with
external input hardware.  Half of which will use pulse detector
logic and latches.  The rest will function as sense switches to
alter what the LCD displays are doing.
All in all it is going very smoothly.  Once I get it finalized I
will then see what the minimal AVR hardware is necessary and maybe
make a custom PCB to mount it all.
-Tony
there a
> > structure elements?
> Yes, and yes.
--- In AVR-Chat@yahoogroups.com, Dennis Clark <dlc@f...> wrote:
> Tony,
one to
> EEWE.
write
> accessing the
Register
> will be
> recommended to have
these
> problems.
EEPROM.
> DLC
OOOOPS.  That last part, 4 clock cyles, is pretty critical timing.
I COULD disable interrupts for just step 4 and 5.
I can modify the code for the  Libc eeprom code to suit that.  This
is a very brief suspension. of the interrupts.
What I do not want to do is to disable interupts for the entire
duration of a multi-byte eeprom write.  That could be many many
milliseconds.  But if the interrupts are suspended briefly, but
repetetively, then that is not really a problem.
Do you think it is necessary to have interrupts suspended for all
the steps?  Is there a limit to the duration of data sitting on the
eeprom data registers?  Actually it does not seem as if all the
steps between 2-5 would take that long.  While step 1 is waiting,
interupts could be enabled.
I will check the atmega128 docs on eeprom reading and writing.  I
printed the pertinent info out, but did not yet read it since the
I had such luck with the built-in funtions.  Of course right now, I
only have the millisecond timer interrupt occuring.  In real life I
would have an external interrupt triggering at a regualr, but
probably slow (10's of ms) rate.
I will see if I can find the C/ASM code for the eeprom so I can hand-
tune the interrupts.
-Tony
EEPROM:
OK, I like this technique because _I_ do not have to keep track of
the address of variables in EEPROM.  But....
Always a but.  How do I use this command.  I tried it in the C
source inside main().  This gave errors.
I then put it into the makefile, and I got no errors, but who knows
what it did with the command.  When I referenced the variable, I got
an "undeclared" error.
So, where I I put the command you suggest, and then how do I use the
resulting variable?
-Tony
2005-04-26 by Dennis Clark
>>Tony,
> one to
>>EEWE.
> write
>>accessing the
> Register
>>will be
>>recommended to have
> these
>>problems.
> EEPROM.
>>DLC
Yup.
Those are the only timing critical steps, that is what I'd do.
> -Tony
DLC
2005-04-26 by David Kelly
I haven't looked at the avr-libc version but wrote my own, it ain't that
hard. However this code hasn't been tested yet:
//	write to EEPROM
//		addr is the address within the EEPROM
//		cp is where to read data in RAM
//		n is the number of 8 bit octets to copy
void
ee_writes(uint16_t addr, void *cp, uint8_t n)
	for( ; n ; n-- ) {
		wdt_reset();
		while( EECR & (1<<EEWE) )	//  wait until ready
		EEAR = addr & (2048-1);	//  stripped to 11 bits, 2kB
		EEDR = *((uint8_t*)(cp)++);	//  looks frightening
		addr++;
		cli();			//  an IRQ would ruin this timing
		EECR |= (1<<EEMWE);	//  only stays set for 4 clocks
		EECR |= (1<<EEWE);	//  hit EEWE before EEMWE clears
		sei();			//  assume IRQ was enabled
> resulting variable?
I don't quite follow your problem. Does this answer your question?
#include <avr/eeprom.h>
typedef struct {
	int	a,
		b,
		c;
	char	s[32];
} EEDATA;
EEDATA eedata __attribute__ ((section (".eeprom")));
EEDATA data;
void
main()
	while(1) {
		data.a = 0;
		eeprom_read_block( &data, &eedata, sizeof(data) );
		data.a++;
		eeprom_write_block( &data, &eedata, sizeof(data) );
This makes sense.  Did you truncate off the high bits down to (2048-
1)because the CPU you were using had only 2k bytes of EERPROM?
Since the 128 has 4K, I guess then the address would be truncated to
(4096-1)?
-Tony
timing.
This
ain't that
> //	write to EEPROM
> void
> 	for( ; n ; n-- ) {
> 		wdt_reset();
> 		addr++;
timing
clocks
clears
> typedef struct {
> 	int	a,
> 		b,
> 		c;
> 	char	s[32];
> } EEDATA;
> EEDATA data;
> void
> main()
> 	while(1) {
> 		data.a = 0;
> 		data.a++;
Yes, this does show it explicitly.  I tried something similar, but
allocated individual variables instead of a structure because I will
nearly always be accessing them totally individually, only once in
the beginning as a block.
When I did this and initialized the eeprom variables, I got odd,
numbers looking like uninitialized data (in avr studio watch
screens).  When I read and wrote them I still got numbers that were
not the uninitialized strange #'s.  I will look at this more....
-Tony
2005-04-27 by David Kelly
> (4096-1)?
The target is intended to be an ATmega64L, so when I code that is the
manual I'm looking at. Is only recently I've had my 64L target hardware
running so previously was loading on a MAVRIC-II and staying within the
64 subset on the 128.
Masking values to the available range is an old habit in attempt to
fail in a safe way and doesn't do much good here. No doubt if one tries
to write a value too large to EEAR the effective address will be masked
and wrapped-around by the hardware. And if one aims to be safe, thats
the wrong way to do it. If out of range the read/write should be
ignored, not forced to fit.
Have spent some time this afternoon looking at the avr-libc routines
eeprom_read_block() and eeprom_write_block(). If you have looked at the
source code I don't understand your (previous?) concern about IRQ. The
write routine only disables IRQ for the minimum possible interval
exactly the same as mine.
Then I started playing with my ee_writes() and ee_reads() routines in
C, making them closer to the library's assembly routines. My count is
only 8 bits rather than size_t's 16 bits, but my C generates smaller
code by a few bytes. No big deal. But I'd rather have C in my project
than assembly in a standard library when things are this close, and
when its not something as common as memcpy().
In imitation of the assembly routines I copied SREG off into a uint8_t
tmp, cli(), tickled bits, then SREG = tmp;, and only added 2 bytes to
the generated code.
2005-04-27 by arhodes19044
I did like your C version of the eeprom routines.  When I found out
how to see the asm source of the library routine, it was hard to see
what was happening without a listing of all the registers.  Even
then it was inconvenient.
I also saw that the library routines had CLI just before what
appeared to be the time-critical instructions.
I had read SOMEWHERE that the library routines did NOT clear
interrupts, and that it had to be done manually before before eeprom
access.
This is incorrect.  The library routines DO (seem to) clear the
interrupts.  So, I do not have to worry about manually doing it, and
ending up with them cleared for an entire multi-millisecond block
transfer to eeprom.
THANKS!!!
-Tony
(2048-
truncated to
> > (4096-1)?
hardware
within the
to
tries
masked
thats
routines
at the
The
in
is
smaller
project
and
uint8_t
to
> the generated code.
DWEN
2005-09-15 by Jeffrey Engel
Recently I purchased several Tiny13's, but have been
unable to program them via ISP (my only option at the
moment).  After reading through the manual, I'm
guessing that the DWEN fuse is set.
Will Atmel's programmer be able to re-program the fuse
or do I need to purchase the new JTAG / Debug Wire
dongle?
Advice?  Opinion?
Jeff Engel
Arlington, TX
Happiness is - positive intake manifold pressure.
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
Re: DWEN
2005-09-15 by Don Kinzer
My reading of the datasheet is that the Tiny13 is programmable via SPI
as shipped from the factory.  The AVRISP programmer should be capable
of programming the Tiny13 but it looks like the STK500 cannot.  What
ISP do you have?  The Tiny13 may or may not be in its list of
supported devices.
Don
Re: DWEN
2005-09-16 by paul_hvidston
Looking at my notes, I program the ATtiny13 on the STK500 using the
same socket setup as the AT90S2323, AT90S2343, ATtiny12 & ATtiny22.
Paul H.
> supported devices.
> Don
Re: [AVR-Chat] Re: DWEN
2005-09-18 by Jeffrey Engel
> been
> the
> should be capable
> STK500 cannot.  What
> its list of
> supported devices.
> Don
Don,
Thanks for your reply.  I hadn't thought of that.
I'm using the Olimex products to prototype with.
They've worked well with the AT90S8223, but I've been
unable to read or program the Tiny13.
Jeff Engel
Do You Yahoo!?
