AVR-Chat
New to this Avr Microcontroller
2006-05-26 by antony7040
Hi all
I am into building RoV's and use the "robotrov" Yahoo group.
I am going to get into this microcontroller using a avr chip.
What I would like to know is what's out there for me. Yes I have
browsed the web but I need a starting point I.E. the chip. software
I need to control 6 servos or esc's
4 switches on/off
3 sensors depth . temperature. light.
A purpose built control panel with another Avr chip inside.
or if I got 2 a laptop and a joystick to control from topside via RS
232.
I live in the U.K.
there is a store below that looks OK.
http://www.active-robots.com/
I currently use a radio control to control but I gota get into
something that is programmable and upgradeable.
Any input would be most welcome.
Regards Antony(UK)
Re: [AVR-Chat] New to this Avr Microcontroller
2006-05-26 by Jim Wagner
Antony -
There are several very good resources on the internet. One
is AVRFreaks.org Another is AVRbeginners.net.
Jim
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
RE: [AVR-Chat] New to this Avr Microcontroller
2006-05-27 by stevech
Check out
www.zbasic.net
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of antony7040
Sent: Friday, May 26, 2006 3:05 PM
To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] New to this Avr Microcontroller
Hi all
4 switches on/off
232.
I live in the U.K.
Regards Antony(UK)
Yahoo! Groups Links
2006-05-27 by Ralph Hilton
On Fri, 26 May 2006 22:04:36 -0000 you wrote:
>Hi all
>4 switches on/off
http://www.bdmicro.com/mavric-iib/ might be of interest.
Ralph Hilton
http://www.ralphhilton.org
C-Meter: http://www.cmeter.org
FZAOINT http://www.fzaoint.net
2006-05-27 by Reza
--- stevech <stevech@san.rr.com> wrote:
> Check out
> www.zbasic.net
> Of antony7040
> Hi all
> Yahoo group.
> avr chip.
> me. Yes I have
> chip. software
> 4 switches on/off
> inside.
> from topside via RS
> 232.
> I live in the U.K.
> gota get into
> Regards Antony(UK)
For development tools, I tested many, but best ones
are:
CodeVision AVR Compiler.
-- use this compiler if you want to test something or
even just write a program to do something simple. It
is not a good for best performance or good
programmers.
GNU C/C++ Compiler or GCC.
-- This is the best I found. you can download from
www.sourceforge.net
looking for WinAVR project.
but this is a command line compiler which is hard to
use. you can download AVRStudio 4.12 with SP2 from
atmel site. install GCC, then install AVR studio.
you can write programs very simple and easy.
To program AVR micros, use ponyprog2000 or AVReal
1.25.
ponyprog is a general perpose serial programmer and
has a GUI, but in some cases, the AVReal (which is a
command line tool) is more faster and better than the
others. specially when you want to clock the micro by
PC in programming time.
for some helper sources, google for avrlib.
good luck;
reza
Do You Yahoo!?
http://mail.yahoo.com
AVR programmer for beginer
2006-05-27 by xolang1
Hi
Anyone know a link to a hardware programmer for the AVR
that is compatible with codevision AVR?
Ideally, it should be simple for a beginner yet tried and tested
any help would be appreciated
Do you Yahoo!?
Get on board. You're invited to try the new Yahoo! Mail Beta.
FLIP for STK525 - "Device protection is set"
2006-05-27 by Peter Gargano
I zapped the fuses on the AT90USB1287 that comes with the STK525 and
now the Flip bootloader doesn't work. I tried obvious combinations of
fuse setting after reprogramming with "bl_usb.a90", but I can't get
Flip to load code into the AVR. Flip tells me "Device protection is
set"! - All is not lost, I can still ISP program the board, but I'd
like to know what the fuses should be set to.
Anyone with an STK525, can they tell me what fuses are set on the 1287?
Peter.
RE: [AVR-Chat] AVR programmer for beginer
2006-05-27 by Roy
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.7.2/349 - Release Date: 26/05/2006
Re: [AVR-Chat] FLIP for STK525 - "Device protection is set"
2006-05-27 by John Samperi
You are SO privileged just to have a 1287!! I can't even
get price and availability for a 1286 (or a 646) for over
a weekso I had to revert to the good old FTDI chip and an AVR.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
2006-05-28 by Peter Gargano
Hmm, then I won't tell you I also have five (5) MAX3421E samples then!
Talk to Archna at Soanar. Maybe she pulled some strings for me?
But seriously, if you want just device mode USB, and still want to
stay with Atmel, then the ARM7 chips look quite good. I'll be very
happy when ARM7 gets USB host-mode (have to go to ARM9 for that, and
then that's using external flash, and expensive!). ARM7 is now very
cheap ...
   http://www.atmel.com/dyn/products/product_card.asp?part_id=3521
BTW, I'm looking at using the 1287 in host mode, and the MAX3421E, as
an SPI peripheral, does this. But they both suffer from real-world
supply problems. And, as far as host-mode USB mass-storage class
drivers go, they both suffer from a lack of example code. Atmel in
France (Jean-Christophe) assure me however that they will release code
(NDA) this June.  Parts mentioned can be found here ..
   http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3639
   http://www.atmel.com/dyn/products/product_card.asp?part_id=3875
Peter.
2006-05-28 by Roy
I am personally thinking of buying the AVR-USB-JTAG OPTOISOLATED USB JTAG DONGLE FOR PROGRAMMING AND EMULATION as shown at http://www.olimex.com/dev/index.html
It is available from various suppliers.
Has any one had any experience with using this unit?
Feel the power of the dark side!
Atmel AVR
Roy Hopkins
Tauranga
New Zealand
2006-05-28 by John Samperi
For an application that needs 5 i/o and about 500 bytes of
flash (written in assembler 50K in C)? :-D The clients unfortunately
wants USB connectivity, so I thought I'd be smart and use the USB646
(not available yet) so I went for the USB1287 which is SUPPOSEDLY
available NOW, still no reply as far as price and availability and
cannot even found on O/S web sites like Avnet etc.. so it's back to
the good old tiny2313 and ftdi232r which gives me almost a component
free application as the clock is internally generated and all USB
components are built in, I will only need a few 100nF caps.
John Samperi
John Samperi wrote:
> .. so it's back to
I think FTDI would have sold more of these devices if they had made
available a DIP package. Either the 232 or the 245 are, and will
remain, very good quick solutions. But, if absolute reliability is not
too much of an issue, you can do a USB device with just the 2313 - see
AVR309. The firmware needs a very small mod to assemble under studio
4.12 and there's a working version for the Mega-8 in the zip file too.
I tried it the other day and the demo source code assembled and works
a treat, even comes with a Win32 Application. But remember there's
little error checking and it relies on a noise free environment, so
it's a hobby-solution rather than a real-world solution ...
http://www.atmel.com/dyn/products/app_notes.asp?family_id=607&part_id=2018
Peter.
Re: AVR programmer for beginer
2006-05-28 by txt me
has anyone tried using this particular programmer:
http://www.serasidis.gr/circuits/avrprog/avrprog.htm
with ATmega16 or ATmega32?
--- In AVR-Chat@yahoogroups.com, "Roy" <roy.h@...> wrote:
> Check out these – not in any particular order.
> HYPERLINK
> "http://www.serasidis.gr/circuits/avrprog/avrprog.htm"http://www.se
rasid
> HYPERLINK
> "http://www.lancos.com/prog.html"http://www.lancos.com/prog.html
> HYPERLINK
> "http://microcontrollershop.com/default.php?
cPath=110"http://microcontro
> llershop.com/default.php?cPath=110
> HYPERLINK
> "http://www.qsl.net/wd6cmu/avr910.htm"http://www.qsl.net/wd6cmu/avr
910.h
> tm
> HYPERLINK
> "http://www.avrfreaks.net/index.php?
module=FreaksTools&func=viewItem&ite
> m_id=367"http://www.avrfreaks.net/index.php?
> Item&item_id=367
> HYPERLINK "http://www.qsl.net/ba1fb/"http://www.qsl.net/ba1fb/
> HYPERLINK
> "http://elm-chan.org/works/avrx/report_e.html"http://elm-
chan.org/works/
> avrx/report_e.html
> HYPERLINK
> "http://www.siwawi.arubi.uni-
kl.de/avr_projects/evertool/"http://www.siw
> awi.arubi.uni-kl.de/avr_projects/evertool/
> HYPERLINK
> "http://www.myplace.nu/avr/yaap/"http://www.myplace.nu/avr/yaap/
> HYPERLINK
> "http://www.kanda.com/index.php3?
bc=partno&bw=STK200"http://www.kanda.co
> m/index.php3?bc=partno&bw=STK200
> HYPERLINK
> "http://www.siliconchip.com.au/cms/A_30487/article.html"http://www.
silic
> HYPERLINK
> "http://sourceforge.net/projects/winavr/"http://sourceforge.net/pro
jects
> /winavr/    This link is to WINAVR a free C programming tool that
runs
> under AVR studio
Re: [AVR-Chat] Re: AVR programmer for beginer
2006-05-29 by James Ronald
I have not tried the ISP cable below but I do use (since last night) the ISP cable described on page 33 of the AVR Robot Controller 1.1 which is used in the SRS Workshop Robot.
Sent: Sunday, May 28, 2006 9:58 PM
Subject: [AVR-Chat] Re: AVR programmer for beginer
--- In AVR-Chat@yahoogroups.com, "Roy" wrote:
> Check out these - not in any particular order.
> HYPERLINK
rasid
> HYPERLINK
> HYPERLINK
> HYPERLINK
910.h
> tm
> HYPERLINK
> Item&item_id=367
> HYPERLINK
chan.org/works/
> avrx/report_e.html
> HYPERLINK
> HYPERLINK
> HYPERLINK
> HYPERLINK
silic
> HYPERLINK
jects
runs
> under AVR studio
------------------------ Yahoo! Groups Sponsor --------------------~-->
Protect your PC from spy ware with award winning anti spy technology. It's free.
http://us.click.yahoo.com/97bhrC/LGxNAA/yQLSAA/dN_tlB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/AVR-Chat/
<*> To unsubscribe from this group, send an email to:
AVR-Chat-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
JTAGICE MKII NO ISP
2006-06-01 by OWEN-A
Has anyone had a problem with an ATMEL JTAGICE MKII that will not enter the
isp programming mode.
I also have the early model ATMEL JTAGICE that enters isp and programs fuses
/ lock bits OK using the same board and connector as the MkII has the
problem with.
I am using Studio 4.12  SP2  Build472.
Thanking You,
Owen.
Re: [AVR-Chat] AVR programmer for beginer
2006-06-06 by Ned Konz
Roy wrote:
> I am personally thinking of buying the *AVR-USB-JTAG* OPTOISOLATED USB
Yes; I've got one. Works fine. However, make sure that it programs all
the devices you want to program; I had to get an AVR JTAG mkII to
program some of the newer devices (especially the ATTiny25/45/85).
Ned Konz
ned@bike-nomad.com
http://bike-nomad.com
2006-06-09 by Roy
Thanks Ned for the heads up :-)
Doesn't just interface to AVR studio, so long as this has the chips are
in the studio would this not work?
I have studio version 4.12 - is this the version you have?
Will email olimex to see what they say as I want to order one soon.
Atmel AVR
Roy Hopkins
Tauranga
New Zealand
Behalf
> Of Ned Konz
> Sent: Tuesday, 6 June 2006 2:15 p.m.
> Subject: Re: [AVR-Chat] AVR programmer for beginer
USB
> Thanks,
> Ned Konz
> ned@bike-nomad.com
Version: 7.1.394 / Virus Database: 268.8.3/359 - Release Date: 8/06/2006
2006-06-09 by Ned Konz
I don't generally use AVR Studio, as I don't generally use Windows.
However, the interface to the Olimex unit is the same as the JTAG 1 from
Atmel, and it will work with both AVR Studio, AVRDude, and avarice.
Any chips that are supported by the Atmel JTAG I will be supported by
the Olimex unit; look at the help file for the JTAG I in AVR studio.
> Atmel AVR
> Roy Hopkins
> Tauranga
> New Zealand
>> -----Original Message-----
> Behalf
>> Of Ned Konz
> USB
>> Thanks,
>> Ned Konz
>> ned@bike-nomad.com
Ned Konz
ned@bike-nomad.com
