Bootloader Frustration
2007-07-12 by Dave VanHorn
Hmm.. Having much fun trying to implement this.. The basics of the Xmodem transfer protocol are working, and I get 128 byte packets from the host. But putting them into program memory isn't working out right. I have a register that counts packets from the host, of course it rolls at 255, so I grab another register that counts rollovers. 1024 packets of 128 bytes fills a M128. Here's how I translate the packet count to the write address: ; ;*********************************************************** ; ; Create the page pointer in three DIFFERENT registers. ; from the Xmodem packet count, and ITEMP, which is used ; as the high byte, since we have no INTS at this point. ; Loader_MakePage: lds TEMP,XmodemBlk ; call Pong ; clr ZL ; out RAMPZ,ZL ; ; RAMPZ ZH ZL ;00000000 xxxxxxxx 00000000 lds ZH,XmodemBlk ;The packet number ;00000000 pppppppp 00000000 dec ZH ; ;packet 1 goes to block zero ;00000000 bbbbbbbb 00000000 lsr ZH ;shifts a 0 into MSB of ZH ror ZL ;shifts carry into MSB of ZL ; RAMPZ ZH ZL ;00000000 0bbbbbbb b0000000 ; | || || ; | || |\----- Which byte within word ; | |\----\------ Words within page ; \----------\------------ Pages mov TEMP,ITEMP ;UGLY fix for how they bastardized the andi TEMP,$03 ;000000xx breq MakePage_NOZ ;If neither bit is set, then done. sbrc TEMP,0 ;If lsb is set, then set MSB of ZH ori ZH,$80 ;dosen't touch TEMP ;00000000 Bbbbbbbb b000000 sbrs TEMP,1 ;if b1 is set, then set B0 of RAMPZ rjmp MakePage_Noz ; ldi TEMP,$01 ; out RAMPZ,TEMP ; ;00000001 Bbbbbbbb b0000000 ; | || || ; | || |\----- Which byte within word ; | |\----\------ Words within page ; \----------\------------ Pages MakePage_Noz: in TEMP,RAMPZ ;So I can see the adrs on the LA call PONG mov TEMP,ZH call Pong mov TEMP,ZL call Pong ret ; ;*********************************************************** ; What's happening, is that it seems to be erasing EVERY page, but writing every OTHER page, although I can't tell if it's wrapping, or exactly what is going on.. The "pong" statements are my byte in PWM output on a single pin, and that shows me what I expect as the packets come in.
