At 22:39 11.08.01 -0400, you wrote:
>> then you might be able to tell me what are the 8 connections of the relais
>> on the the CZ-1 output board are for. It seem to be broken so I made a
>> connection between Pin 3 + 7 and 4 + 8 and it seems to work know but I don't
>> know what 5 + 6 is for...
>> Pin (don't know if I numbered the connectoins right)
>> 1 2 seem to be the connection for the switch power of the relais
>> 3 4 L + R one end of the switch
>> 5 6 don't know....
>> 7 8 L + R other end of the switch
many thanx for the info...
>the schematic shows it as a 16-pin chip, with 8 pins used.
The pins parallel to the left and the right don't belong to the unit, at
least not in my CZ-1...
>pins 1,16 are the coil
>pins 4,13 are outputs, L,R (B,A)
>pins 6,11 are 2.7K dummy-load
>pins 8,9 are inputs
Ok, so it was the right decision to connect 8 with 4 and 9 with 13... it
crackles a little when turning on the synth, but I think it's easier then
replacing the chip (what is the right english name for a "electrical
triggered switch", "Relay" ???) and the ouputs are working fine again. My
guess that this little thing is causing problems in many Casio synths after
some years...
I first thought the unit has problems with A/B know, since on the headphone
output it seemed to be not hard left and hard right anymore but now after I
connected it to the mixer again the line outs seem to be ok that's why I
asked for the pinout...
Another thing, there are 3 adjustable resistors on the same board, one is
for the headphone output but I haven't found out what the other two (sitting
close to each other) for. I may have changed their value while trying out
what causes the output to have problems. It would be nice if you look up
their purpose?
>(testing yahoo support of ascii-scematics)
>(this is sent as a box)
Well, the box is ok here, maybe it's because I'm using an ascii only
mailprogramm... I still think it was a bad idea to use HTML in mail programms...
>also, i'll see if it mentions it at all, but my guess is that it's just
>used to mute the outputs while changing patches, loading data, etc.
It's reacting shortly after turning on the synth and stays that way... a
friend had the same problem with his FZ-1, but it was harder to find since
it wasn't on the output board. But the FZ relay had only 4 pins...
Ok, thanx again for your help!
Summa
+++++++/++\++/++++++\++/+++ \ /\ /\ / O
+ Nicknames : Summa or SumGhost
+ AIM : Flotorian
+ Born : 1967
+ Profession : Student of Computer Science
A Touch of Future - Project : http://www.mp3.com/AToF/
Casio CZ Synth Station : http://www.mp3.com/stations/CZ/
CZ/VZ Mailinglist : http://groups.yahoo.com/group/CZsynth
Boycott the Premium Artist Service!!!
_________________________________________________________
Do You Yahoo!?
Get your free @... address at http://mail.yahoo.com
