Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
CZ-1, I really need some feedback on my problem.
2006-05-16 by michaeldavidstein
Heres the story. I bought a CZ-1 that should have been a simple fix. So
far I have replced most all of the tactile switches on the board under
the parameter controls. This side of the board looked to had been spilt
on and most these functions were unaccessible. Now I have all of these
controls back with the replacements. Next I just replaced the internal
memory battery. I am experiencing the same kind of volume problem as
group member discussed on earlier post. This is my first time using a
CZ or digitally programmed synth. I do not know how to save new
patches, when i press write it asks where I want to save to?. some of
my keys velocity is terrible, I would like to turn the velocity
function off. I am fearing that this keyboard has to many problems I
cannot fix. I would like to get a hold of a sound cartridge to see if
when plugged in, my synth jumps to life but right now even when I go
through and change many parameters I hardly get a change in its sound
or it goes into some crazy sustain mode were I hit a key and it plays
out for like over 30 seconds. Is there a way to reset its original
parameters for the factory presets to come back?  I also have two keys
that wont play and one you have to press very hard, after cleaning the
contacts underneath these keys there was no improvement. Any
suggestions or comments would be greatly appreciated.
thanks,
-michael-
Re: [CZsynth] CZ-1, I really need some feedback on my problem.
2006-05-16 by Manu
Power Off the synth. Push the red button on the top right, "Initialize"
and maintain it pushed. Power the synth on, and you will be asked in the
LCD to reset it to defaults. Push "Yes", it's at the bottom of the lcd,
at the right, with a right arrow on it. Now, release the "Initialize"
button. Done :)
Manu
Re: CZ-1, I really need some feedback on my problem.
Thank you very much, and also at the top middle/right where you can
pick between like 1  2  1-2  2-2, something like that. it always jumps
to the second one everytime i change the preset in which it will not
make sound so i have to push the button three times everytime to get it
back to the first one where it will sound out of the output. is this
normal behavior and what do those options represent. I know it has to
be on the last one for me to select noise or ring modulator.
thanks,
-michael-
sorry for being unknowledgable about this synth. I will pick up a
manuel soon.
right, "Initialize"
lcd,
> button. Done :)
> Manu
Re: [CZsynth] Re: CZ-1, I really need some feedback on my problem.
2006-05-16 by Manu
> it always jumps
I have had my CZ-1 only four days, but I think that's the normal
behaviour. Mine makes the same. Different presets change it :)
Manu
CZ-1 volume fixed, now it's time for the pitch bend control
2006-05-18 by Manu
Finally found it! Three broken solder pads, corresponding to the legs of
one of the 2SB632K power amps. Soldering the legs again has fixed the
audio volume problems :)
Now, I have one more question for you guys. Pitch bend on my CZ-1 works
about 5.5 semitones down and only 0.5 semitones up. Does anyone have a
rational explanation for this? I get random small changes in the pitch
that last between 0.1 to 4 or 5 seconds, and I'm not sure if this could
be related. Maybe the potentiometer is defective?
Thanks a lot in advance! :)
Manu
RE: [CZsynth] CZ-1 volume fixed, now it's time for the pitch bend control
2006-05-18 by Scott Nordlund
Test the voltage and see what it does...
Re: [CZsynth] CZ-1 volume fixed, now it's time for the pitch bend control
2006-05-18 by Manu
I tested the voltage between the first and second pins, and it stays at
1.20 nearly all the time, but sometimes it drops to 1.00 or raises until
1.25, and when this happens the sound changes the pitch. When the sound
is at 1.25 (about one semitone up) I can't use the pitch bend to raise
it even more, I can only lower it some semitones. I bet this means a bad
potentiometer, or a bad voltage coming into it. I'll try to buy another
one, it's a 618k audio pot, am I right? I still haven't tested the third
pin because the random nature of the problem, but I'm at it.
Manu
2006-05-19 by Scott Nordlund
You should measure with respect to ground.  The typical configuration for
pitch/mod wheels is that the potentiometer goes between the positive and
negative supply voltages (or positive and ground), and the wiper (middle
terminal) goes to an ADC.  The potentiometer here acts as a voltage divider
and the voltage at the wiper terminal varies from one supply voltage to the
other (or whatever it's connected to).
2006-05-24 by Manu
Today I replaced the pitch bend pot and all the problems disappeared...
  Fixed! :)
The bad thing is that I've been unable to find a 618k pot to replace the
original. I bought one of 1000k (1 meg ohm), but I'm not sure if this
can be dangerous or not. If someone can throw some light into this issue
I would be very very grateful! :) For now I have not tried to turn it
until the limits, I just turned it half then moved it a bit until C was
C and not D# :) It's been working without any problem for about five
hours now.
Thanks a lot,
Manu
2006-05-26 by Scott Nordlund
>hours now.
It shouldn't be a problem at all.
