Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
Make your own Casio VZ/PG RAM card!!
2007-06-01 by gmeredith1
Hi Everybody!
I've managed to get hold of the schematics for the very rare RA500 RAM
card, used in the Casio VZ1/10M/8M and the Casio PG guitar synths,
thanks to Steve at the EZ-VZ forum website. It will now be possible to
make one of these RAM cards yourself for about $20!!
I'm in the process of making up a step-by-step guide with photos, which
I will upload to the FILES section here when I've finished them. In the
meantime, for anyone who's good with electronics, I've uploaded the
RA500 card schematics there, along with datasheets and other info, so
you can start straight away!!
Cheers, Graham
Re: Make your own Casio VZ/PG RAM card!!
2007-06-01 by Fulfil Objective
Fantastic!  I'm glad that you're going to do a tutorial about it.  Not
only are you solving your own problem, but you'll give everybody else
the bug to do it too.  And that will keep all these synths around
longer.  I can't wait to see the outcome.  Hope it goes smoothly!
--- In CZsynth@yahoogroups.com, "gmeredith1" <gmeredith1@...> wrote:
> Hi Everybody!
> Cheers, Graham
RE: [CZsynth] Make your own Casio VZ/PG RAM card!!
2007-06-04 by Scott Nordlund
It would be easy to make a larger capacity card: just get a bigger RAM chip
(1 Mbit would give you 4 banks), and use DIP switches or something for the
additional address lines.  Or, multiple chips could be stacked and switched
using the CS line.  It just depends on what chips are available.  I think
the only hard part would be finding a suitable connector.
Do you have a schematic for the ROM cards?  I think it would be possible (if
not particularly pretty) to use a ROM card as a starting point (making
changes to account for the difference in the way ROM/RAM cards are
detected).  If the ROM chip has a CS line, it would probably be pretty
simple to add a switch to choose either ROM sounds or RAM sounds.
>From: "gmeredith1" <gmeredith1@...>
>Reply-To: CZsynth@yahoogroups.com
>Subject: [CZsynth] Make your own Casio VZ/PG RAM card!!
>Date: Fri, 01 Jun 2007 02:17:00 -0000
>Hi Everybody!
>Cheers, Graham
Don\ufffdt miss your chance to WIN $10,000 and other great prizes from Microsoft
Office Live http://clk.atdmt.com/MRT/go/aub0540003042mrt/direct/01/
2007-06-05 by gmeredith1
Hi Scott,
I just got sent a photo of a ROM card opened up. There is not much
difference with the RAM and ROM PCB, the RAM has more etchings and
tracks in it for an extra chip that does switching of the CE (Chip
Enable) pin, and also the WE (Write Enable) pin, both of which the
ROM doesn't need. And a few other differences in the pin track
layouts to the RAM chip, but that's it. I've uploaded a schematic for
the RAM card in the FILES section on this site.
Regarding having a larger chip, the schematics show already that it
was made to accommodate a chip 2x as large as the one used, there is
a spare address line not used on the connector. This is for the ROM
chip, which is 2x larger than the RAM chip (which is why it has an
extra bank of sounds) - The ROM is 512k and the RAM is 256k. It would
require no more effort than dropping in a 512k RAM chip and hooking
up the extra address line. As you say, an even larger chip can be
installed and the highest address lines switched with a DIP switch to
get extra banks.
Cheers, Graham
RAM chip
for the
switched
think
possible (if
(making
pretty
> >Hi Everybody!
RAM
possible to
which
In the
so
> >Cheers, Graham
> Don't miss your chance to WIN $10,000 and other great prizes from
Microsoft
RE: [CZsynth] Re: Make your own Casio VZ/PG RAM card!!
2007-06-05 by Scott Nordlund
I think that was probably my ROM card, actually.
>get extra banks.
Referring to the service manual... apparently a 2-bank RAM card was never
released.  When the VZ detects a RAM card, the highest address bit is
disabled (unless someone wants to modify the OS).  To access both banks (as
it would be useful to have 192 online patches), the VZ needs to detect a ROM
card.  In this mode, it would be impossible to write patches, and likely it
would have to be switched off when changing this to avoid crashing things.
But, if it can be determined how the VZ detects the card type, it could make
things a little more interesting.  From the diagram, it seems like only the
CD (Card Detect?) pin could determine this... but my scan only shows the
component side of the board, and that pin connects to something on the other
side.  This pin is grounded for a RAM card, so inside the VZ it's probably
just pulling down a high value.  But if that's the case, I'm not sure what a
ROM card could do differently.... I can take my card apart again if
necessary (though it's sort of damaged enough already...)
Actually, maybe this should be verified.  If anyone has a RAM card, I would
appreciate it if this could be tested:  When a RAM card is inserted and the
CARD button is pressed multiple times, does it switch banks between CARD (1)
and CARD (2)?  If it does, that means it is actually using the highest
address bit, but since it's not connected, it's still just looking at the
same data.  Seems like it would be bad design to do it this way, but it's
possible.  I suspect a RAM card just shows up as CARD, with no indication of
bank.
Get a preview of Live Earth, the hottest event this summer - only on MSN
http://liveearth.msn.com?source=msntaglineliveearthhm
2007-06-06 by gmeredith1
Hi Scott,
Thanks for the sacrificial ROM scan!
Regarding card detection, all that the VZ does to detect a card,
whether a ROM or RAM, is check to see if pin 44 is low (grounded). If
so, then the software allows the the data lines to be read, again,
either RAM or ROM.
To activate the RAM, pin 32 connects a high signal from the VZ port
to the CE (Chip Enable) pin on the RAM chip, via a NOR gate chip,
which pin 35 (high) also operates.  The ROM chip is disconnected from
both these pins, as it is always enabled.
So the only difference between the 2 cards seems to be the extra
address line RA15, which is connected to the highest address line A15
on the ROM chip, but not connected to anything on the RAM chip. I
don't know what means the VZ has to display "no bank", as you say, it
would be interesting if someone could put in their RAM card and
switch through the banks and see what it displays.
In any case, I don't think the VZ sees any difference between a ROM
and a RAM, except that it will fail to write to a ROM because the
ROM's write line is not connected (and wouldn't work if it was,
anyway.). This being the case, using a larger RAM  chip will give you
an extra bank WITHOUT DIP switch selectors for extra address lines,
because you can use RA15, which is disconnected on the RAM card, but
is utilised on the ROM, being 2x larger than the RAM. For even more
banks, you will need DIP switch selectors though.
Cheers, Graham
for
is
would
to
> >get extra banks.
never
is
banks (as
detect a ROM
likely it
things.
could make
only the
shows the
the other
probably
sure what a
I would
and the
CARD (1)
highest
at the
but it's
indication of
> bank.
on MSN
2007-06-06 by Scott Nordlund
This may be the case, and I notice on mine that it does appear to try to
write to the ROM card before giving an error message.  But I was thinking
that this might not be a great idea- the ROM chip doesn't have the WE pin,
and what are I/O pins on a RAM chip are just outputs.  I would assume that
the VZ just blindly tries to write the data by asserting WE and then sending
the data (if it hasn't got any way to tell), but on a ROM chip this results
in output connected to output, basically a short circuit.  There are 1K
resistors on the I/O lines, but it still seems like it's not the best way to
do things, and I think any decently-engineered product wouldn't do that.
But regardless.. how, then, would it give an error message after trying to
write to a ROM card?  If the VZ doesn't differentiate between RAM and ROM
cards, there's no way to reliably detect a write error.  Even comparing the
data on the card with the internal VZ RAM after the write isn't a foolproof
way to do it.
However, now that I think about it a little more, there are ways to detect
the difference in software.  If there's some unused portion of the memory
space, it's easy to tell if the highest address bit actually does something:
If ROM card address 0x0000 (bank 1) contains the value "10101010" and
address 0x4000 (bank 2) contains "01010101", 0x0000 XOR 0x4000 = "11111111".
  On a RAM card, it would simply refer to the same byte, so 0x0000 XOR
0x4000 = "00000000" (regardless of what data is present).  Whether the VZ
does it on start up or just before attempting to write is a different issue,
but it would thwart the 2-bank RAM card idea.
At any rate, if a RAM card indicates CARD (1) and CARD (2), this would
confirm that the highest address bit is being used, just not connected to
anything, and that RAM and ROM cards are indeed detected the same, at least
on startup (and thus a 2-bank RAM card can probably be used, unless it
detects before attempting to write).
I suspect that the VZ doesn't use software to detect the difference
between a RAM and a ROM card. There are other conditions that must be
met other than just the WE pin, before writing can commence.
It may be that the VZ looks for a completed circuit between the CE,
CE1 and RA19 pins on the card before writing, all of which connect to
the NOR gate chip and then go to the CS pin on the RAM chip, but are
all not connected in the ROM chip.
Also, CE1 on the RAM chip is permanently high, but not connected on
the ROM chip. Without all those conditions being met, the VZ perhaps
will not go into transmit mode. The "write fail" message may appear
as a result of a negative scan result of CE, CE1  and RA19 lines, not
because of failed data transmissions. Maybe.
Having said that, if none of that is true, and the VZ  is able to
blindly "write" to a ROM, the 1k resistors will indeed be protection
against any data signal, I would think. But I think the above
scenario is the case, rather than this one. That being true, IF it is
true, then the extra data line RA15 may be availiable for a bigger
RAM. In any case, I will be trying this out as soon as I get my VZ10M
in about 6 weeks. In the meantime, I'm going to breadboard up a
prototype card. I've already located a source for the standard RAM
chip:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?
langId=-1&storeId=10001&catalogId=10001&productId=279857&pa=279857PS
And a 16x one here:
langId=-1&storeId=10001&catalogId=10001&productId=280049&pa=280049PS
Both very cheap.
Here's the NOR gate:
http://www1.jaycar.com.au/productView.asp?
ID=ZC4827&CATID=33&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=
&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=884
Cheers, Graham
you
but
try to
thinking
WE pin,
assume that
then sending
results
are 1K
best way to
that.
trying to
and ROM
comparing the
foolproof
> way to do it.
detect
memory
something:
and
= "11111111".
XOR
the VZ
different issue,
would
connected to
at least
it
on MSN
