Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
Fwd: [akaiS1000S1100Samplers] Experiences with Datram loading from alternative sources?
2012-01-24 by Jason Adkins
Begin forwarded message:
> From: Markus <emulander@...>
> Date: 24 January 2012 15:58:18 GMT
> To: "akaiS1000S1100Samplers@yahoogroups.com" <akaiS1000S1100Samplers@yahoogroups.com
> Subject: Re: [akaiS1000S1100Samplers] Experiences with Datram
> Reply-To: akaiS1000S1100Samplers@yahoogroups.com
> hi jason,
> i mean memory dat backups on audiodattapes.
> in the 90s you could buy some of them from ueberschall instead of
> cdroms also.
> if you listen to them on an audiotape you hear the computerdata and
> the audio.
> so you could take the audio and cut it manually, but then you do not
> have all the work for
> building the programms keygroups restored.
> autoslicing of the audio is also not possible because the s1000 was
> leaving no audiogaps, so
> every autoslicetool thinks each volume is one 32 mb audioclip.
> mark
> Am 24.01.2012 um 14:26 schrieb Jason Adkins <jason_ralf808@...
>> Hi Mark,
>> You mean SCSI DAT streamers with Akai data on them or do you mean
>> you have audio on the DAT as well as the data or do you mean just
>> pure audio?
>> Jason
>> On 24 Jan 2012, at 13:05, emulander wrote:
>>> Hi all,
>>> do you have Experiences with Datram loading from alternative
>>> sources? Like a pc or mac from dattape i can load all from a pc -
>>> file (recorded from the same tapes) only 2-3 percent of the volumes.
>>> Is there any other way to get files from datrams back or a
>>> software which can convert the volumes out of the datramaudiofile?
>>> Thanks
>>> Mark
