Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
Modifying an RC100 ROM card into an RA500 RAM card
2012-04-20 by Graham
So now that my old dead RA500 RAM card has been replaced, I decided to cut the old one open to have a look inside. If it wasn't too different to the reasonably common and cheap RC100 it might be possible to convert a ROM card into an RA500 by pulling out the ROM chip and putting in the RAM chip used in the RA500.
After opening it up, I found that it does look reasonably possible. There are only 2 extra components in there more than the ROM - a small logic chip and a diode. The RAM chip is the same size as the ROM chip and has almost the same pin layout to the ROM, so it would not be hard to re-rout the circuit board tracks to compensate for this. I wrote up my findings and posted them here at Steve's EZ-VZ website if anyone is interested in the possibility of DIY RA-500 RAM cards:
http://www.chatpage.co.uk/easyveezee/
(The most recent posts start at the bottom of the page)
Cheers, Graham
Re: Modifying an RC100 ROM card into an RA500 RAM card
I've also put the card internal photos and parts list and info here on my band's website:
http://www.warningwillrobinson.com.au/index_files/RA500.htm
Cheers, graham
> Cheers, Graham
