Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
MIDI Channel
MIDI Channel
2012-07-06 by Francis Cote
Is it normal my CZ-1000 "forgets" it's midi channel number everything I
turn it off?
Thanks
Francis
Re: [CZsynth] MIDI Channel
2012-07-07 by Peter Sedin
sounds like battery failure..
2012/7/6 Francis Cote <francis.cote@...m>
> Hi,
> turn it off?
> Thanks
> Francis
Mvh
Peter H.K Sedin
Re: MIDI Channel
2012-07-08 by urmeldaehn
thats normal 4 all cz (101, 101, 3000, 5000) i know
--- In CZsynth@yahoogroups.com, Francis Cote <francis.cote@...> wrote:
> Hi,
> turn it off?
> Thanks
> Francis
Re: [CZsynth] Re: MIDI Channel
2012-07-08 by Francis Cote
Thanks!
> > Hi,
> > turn it off?
> > Thanks
> > Francis
2012-07-09 by Lee Borrell
As Peter said - often there is a Cr2016 or similar battery in synthesizers that lasts 5 years to backup the memory - I can't swear if I saw one last time I opened up my CZ's - but I know the cartridges have them - so odds on the machines do. Yamaha also use the same system. My 1000 is certainly forgetting everything when I sw-off - I must check that out.
To: CZsynth@yahoogroups.com
Sent: Saturday, 7 July 2012, 15:52
Subject: Re: [CZsynth] MIDI Channel
2012/7/6 Francis Cote <francis.cote@...>
> Hi,
> turn it off?
> Thanks
> Francis
Mvh
Peter H.K Sedin
2012-07-09 by jing garcia
Yes! Coz it doesn't have internal battery to save anything after turning the power off.
Unless there's D batteries in the compartment or continuosly connected to a power supply.
That's how I understand it.
With my CZ101, I hot wired a 9v plug in the battery compartment since I always use an external power supply, anyway. the 9v battery usually last several months in keeping data intact. But have to check each time for battery life.
jing garcia
online news editor (infotech)
InterAksyon.com
online news portal of TV5
sent from my blackberry
bb id: 26FE33D5
Sender: CZsynth@yahoogroups.com
Date: Sat, 7 Jul 2012 16:52:49
To: <CZsynth@yahoogroups.com>
Reply-To: CZsynth@yahoogroups.com
> Hi,
> turn it off?
> Thanks
> Francis
Mvh
Peter H.K Sedin
Re: MIDI Channel
2012-07-09 by ROGER
Not a battery failure, CZ1000, 101 & (I Think) the 3000 don't store their midi channel, I just use mine on channel 1 of each midi output of my AKAI MPC, no issues then!
> > Hi,
> > turn it off?
> > Thanks
> > Francis
> Mvh
> Peter H.K Sedin
