To: CZsynth@yahoogroups.com
Sent: Monday, 13 August 2012, 21:59
Subject: [CZsynth] Re: CZ-1 maximum key velocity level
I took my CZ-1 apart and fixed the dead key. I adjusted VR1 and it did not change the velocity. I ranged it from 1.98 vdc to 2.56 vdc with no change in velocity performance. What did make a difference was the silver conductive paint I used to fix the dead key. Now this key responds to velocity better than the other keys. The key contact boards in this synth are gold plated so there wasn't any problems with the boards. The key contact rubber membranes are the problem. The conductive carbon contacts get dirty or wear out. Replacing the conductive carbon coating with the silver repair coating made a difference in velocity response. This key now gets 77 (120) to 7F (128) with a lot less pounding. I guess now I need to do all of the key rubbers... More fun!
--- In CZsynth@yahoogroups.com, "narfman96" <narfman96@...> wrote:
> Ok, this may be way too much fun but here's what I found....
> My CZ-1 outputs 7F (127) for velocity using Midi-Ox to display the notes. I have to really slam the key to get it but will do it. My playing style shows a lot of 66 to 68 (102 to 104) because I never really bang the keys in normal playing.
> Next I looked in the CZ-1 Service Manual which is here in the files section of the group if you don't already have it. The MSM6200 key decoder chip needs a 2.25 vdc reference to work properly. On page 59 (123 in the pdf) it details how to set this reference voltage by adjusting VR1 on the MA1M pcb. You need to look for test point B on page 11 (71) VR1 is near the test point. I would also verify the MSM6200 has a good 5 vdc reference coming in. Page 30 (91) explains the key block diagram details. Page 9 (61) of the schematics shows the keyboard pcb's for the MSM6200.
> You can email me for more details. I have to take my CZ-1 apart to fix a dead key. I can look at more of the details while I'm inside my beast.... I will also verify these refernce voltages.
> Good luck, Fran
> --- In CZsynth@yahoogroups.com, "xelectric123" <xelectric123@> wrote:
> > Hey Lee, thanks for your input, though it won't help much, as it would be a pain to record something from any outboard synth, whether by manually rescaling velocity values, or using MIDI-out from PC with additional software latency.
> > Perhaps there is someone with CZ-1 who could confirm, whether this synth has factory limited max velocity value to 96, or there is something wrong with mine?
> > --- In CZsynth@yahoogroups.com, Lee Borrell <templarser@> wrote:
> > > Whilst this may not be of use to you - you can re-scale velocity using MIDI-ox - the program contains a message modifier - that can basically alter any midi message into any other midi message.
> > > If you tell it to respond to velocity 0-96 with 0-127 then that will solve it - problem is you have a PC strapped to your controller. If the idea is to use the CZ as a controller which goes into a software composer/recorder program - MIDI-ox can be YOKED to the program- that is - pre-process the midi info altering 0-96 to 0-127 before it reaches the composer program.
> > > It's a solution,but a software not a hardware one - so not sure if it suits.
> > > LEE
> > > ________________________________
> > > From: xelectric123 <xelectric123@>
> > > Sent: Friday, 10 August 2012, 10:31
> > > Subject: [CZsynth] CZ-1 maximum key velocity level
> > > Â
> > > Hey guys,
> > > recently my main master keyboard has damaged, so I've temporarily started using CZ-1 to control other synthesizers, as it is my only other keyboard with both velocity and aftertouch control. What I've noticed is that many patches (on other synths) programmed to be expressive with different key velocity sound "different" when played at full velocity. I've connected CZ-1 to DAW, and noticed that no matter how hard I try to struck the keys, the maximum velocity it outputs via MIDI is at 96 level.
> > > I've studied user manual, service manual, tried to find something on the web, but with no luck.
> > > Is it normal behaviour, that this keyboard has key velocity limited do 96? Any tips appreciated. Thanks!
> > > [Non-text portions of this message have been removed]
Yahoo! Groups Links
The information contained in this e-mail message is privileged and
confidential and is for the exclusive use of the addressee. The person
who receives this message and who is not the addressee, one of his
employees or an agent entitled to hand it over to the addressee, is
informed that he may not use, disclose or reproduce the contents
thereof, and is kindly asked to notify the sender and delete the e-mail
immediately.
