On 29 Jan 2014 17:27, "Lee Borrell" <templarser@...> wrote:
>Jose,
>Can you explain the -= in C, is that subtraction?
>It seems your routine is very similar to mine save for the 'twos complement' section - but if you are subtracting rather than adding,perhaps that accounts for it.
>I do not know what the VZ checksum should be anyhow - only yamahas.
>Is the VZ summing all nybbles and then anding with 7f,or is there something more?
>________________________________
> From: José Ángel Morente <msxjam@...>
>To: CZsynth@yahoogroups.com
>Sent: Wednesday, 29 January 2014, 16:18
>Subject: Re: [CZsynth] VZ SysEx Format
>Some time ago I posted a C program used to convert from VZ1 to standard SYX files. You may take a look at the checksum routine, maybe it can be helpful:
>#include <stdio.h>
>#include <stdlib.h>
>#include <string.h>
>#define TONES_NO 64;
>typedef unsigned char byte;
>int main (int argc,char *argv[])
> char *inputfilestream;
> char *outputfilestream;
> FILE *inputfile;
> FILE *outputfile;
> byte tonebuf[336];
> byte operbuf[100];
> byte syxopen[8]={
> 0xf0, 0x44, 0x03, 0x00, 0x70, 0x70, 0x02, 0xf7
> byte syxdata[6]={
> 0xf0, 0x44, 0x03, 0x00, 0x70, 0x74
> byte syxclose[7]={
> 0xf0, 0x44, 0x03, 0x00, 0x70, 0x71, 0xf7
> int i,j,checksum=0;
> byte buffer[10];
> if (argc >= 2) {
> inputfilestream = argv[1];
> if (argc > 2) {
> outputfilestream = argv[2];
> } else {
> outputfilestream = malloc(255);
> strcpy(outputfilestream,inputfilestream);
> outputfilestream = strcat(outputfilestream,".syx");
> inputfile = fopen(inputfilestream,"rb");
> outputfile = fopen(outputfilestream, "wb");
> //write OPEN and DATA sysx messages
> fwrite(syxopen,sizeof(syxopen),1,outputfile);
> fwrite(syxdata,sizeof(syxdata),1,outputfile);
> //process the patches
> for (i=0;i<64;i++) {
> fread(tonebuf,sizeof(tonebuf),1,inputfile);
> checksum = 0;
> for (j=0;j<sizeof(tonebuf);j++) {
> //update the checksum
> checksum -= tonebuf[j];
> buffer[1] = tonebuf[j] & 0x0f;
> buffer[0] = tonebuf[j] >> 4;
> fwrite(buffer,2,1,outputfile);
> //ignores the bit 7
> checksum &= 0x7f;
> fwrite(&checksum,1,1,outputfile);
> //process the operations
> fread(operbuf,sizeof(operbuf),1,inputfile);
> checksum = 0;
> for (j=0;j<sizeof(operbuf);j++) {
> checksum -= operbuf[j];
> buffer[1] = operbuf[j] & 0x0f;
> buffer[0] = operbuf[j] >> 4;
> //ignores the bit 7
> checksum &= 0x7f;
> buffer[0] = 0xf7;
> fwrite(buffer,1,1,outputfile);
> fwrite(syxclose,sizeof(syxclose),1,outputfile);
> fclose(inputfile);
> fclose(outputfile);
> return 0;
>On Sun, Jan 5, 2014 at 10:23 PM, <facebook@...> wrote:
>>Happy new year to all,
>>I spent some time during the holidays setting up an smal HTML5 based framework which is intented to act as a librarian for the VZ sound patches.
>>Going through the specs I came over the checksum, which isn't described in detail in the CasioVZ-HohnerHS Sysex Format.pdf.
>>Can anyone help me out on the details here?
>>My idea:
>>Create a little helper to rearrange existing sysex files, which will (in the first step) be consolidated in a new sysex file to be uploaded.
>>My progress:
>>So far I can drag and drop sysex files into the GUI and extract the tone and op names of the banks, also a re-arrangement is possible (from gui side).
>>My need:
>>Any help on the internal sysex format - especially on the check sum.
>>Technology:
>>HTML5 so anyone could use it. Upload to the VZ would still need an external tool but maybe HTML5 will support that, too in the future.
>>Me:
>>I have a VZ10m, HS-2, CZ-3000 and an HT-3000 in my set-up (besides D-110, X3R, AN1x, Phm and sonic|core Scope 5)
>>Any help is appreciated,
>>cheers,
>>Pete
>>(I was in the forum before but lot my ID after a computer crash ;) )
