2014-10-22 by analogmonster@...
Sorry there is a line missing for some reason, it should read:
Also in the vzs the phase modulation within each line is fixed at a 1:2 ratio. Other ratios are possible by feeding one line into another, but this can be a little limiting sometimes.
On 22 Oct 2014, at 03:04, analogmonster@ymail.com [CZsynth] <CZsynth@yahoogroups.com> wrote:
the iPD used in the vz series is not the same as phase distortion used in the cz series, and is much more comparable to the Yamaha dxs - I imagine this is what jmfreeland is referring to. It's a good question and my opinion (not claiming this as fact just basing it on actually using both synthesis engines) is in principle there is absolutely no difference between Casio vz interactive phase distortion and yamahas frequency modulation (which is really phase modulation)-you have banks of oscillators that you can connect together that can either be used independently/summed together or to modulate each other. The two companies have simply implemented it differently.
If you read the question exactly as you ask it, we should compare the vz engine with specifically the dx7.
Vz have 8 oscillators in 4 lines of 2 oscillators, which can be configured into many different algorithms. Dx7 have 6 oscillators which can be configured into 32 algorithms.
The vz modulating oscillator can be used independently (mixed/additive), to modulate the phase (pm) or modulate the amplitude (am/ring modulation) of the other oscillator in each line. There is no am in the dx7 but there is pm feedback, where an output is fed back into an earlier point in the circuit which the vz can't do. Also in the vzs the phase modulation within each line is fixed at a 1:2 ratio. Other ratios are possible by feeding on
The vz allows multiple wave shapes- sine, 5 different saws with increasing numbers of harmonics, a noise source and a pitched noise source, while the dx7 is sine only.
The vz has 8 stage envelopes while the dx7 has addsr (5 stage) envelopes.
They are both programmed by stepping through multiple pages of menus and using a slider or incremental buttons, but the vz1/10m has a square screen allowing you to eg. view the shape of envelopes while the dx7 is text information on only 2 lines(as is the vz8). But these square screens were a Casio custom order, no one can replace a broken one and they have a habit of dying on you or at least having no backlight any more. The dx7 has membrane keys that die too, while the vz has standard push buttons you can easily replace.
An original dx7 has poor midi implementation (it was one of the first midi synths), stores lots of parameters globally rather than per patch, doesn't do multis or keyboard splits. The vz does do all those things while also having many features even missing from modern synths like velocity curves and key follow curves. But there are dx7 modifications available that add a lot of great features.
The vzs are often said to be cleaner than the dx7. This may partly be down to the DACs, which are 12 bit in the dx7 and 16 bit in the vzs. The dx is mono while the vz is stereo, with quite a few stereo field parameters for making wide patches. The vz10 has xlr outputs which would give a much better signal quality than the dx7s unbalanced mono out.
Im sure there are plenty of other points I have missed but I think that covers most of it. Personally I would choose a vz over a dx7, but would definitely choose a Yamaha tg/sy77 or sy99 over a vz - hundreds of waveforms for fm, you can even use custom samples within the fm engine. Even though I've a tg77 im keeping the vz10 for use with my Casio pg380 midi guitar.
Just remember what Yamaha call frequency modulation is actually phase modulation, and what Casio call interactive phase distortion is also actually phase modulation. Casio probably called it interactive phase distortion to avoid confusion with Yamaha and because it makes it sound like a development of their previous technology from the cz range, phase distortion.
On 21 Oct 2014, at 21:14, Lee Borrell templarser@... [CZsynth] <CZsynth@yahoogroups.com> wrote:
The CZ book by David Crombie and The New Complete Synthesizer by David Crombie and Paul Wiffen explain phase distortion.
http://en.wikipedia.org/wiki/Phase_distortion_synthesis
On Tue, 21/10/14, jmfreeland@... [CZsynth] <CZsynth@yahoogroups.com> wrote:
Subject: [CZsynth] Re: You may like this new VZ demo.
To: CZsynth@yahoogroups.com
Date: Tuesday, 21 October, 2014, 14:00
Are there any good in-depth explanations of the
theory behind iPD and how it compares to DX-7 style FM? I
know the fixed ratio makes for different requirements, and
I'd like to understand where iPD shines and falls
short.
#yiv0125229026 #yiv0125229026 --
