Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
Re: [CZsynth] Beginner
2014-10-17 by Daniel Forró
Hi, Oliver, welcome on board.
On 14 Oct, 2014, at 6:42 AM, oliver.mentel@... [CZsynth] wrote:
> Hi there, my name is Oliver.
> I was just lucky enough to stumble over a 1985 CZ-5000 at my local
> music shop the other day and couldn't resist myself from not getting
> my hands on it.
For sure you will not regret.
> I'm pretty certain, that this may have been on of my best buys for
> the last few years!
Depending on the price - which was probably good - I would think the
same.
> I'm pretty new to this whole exciting world of synthesizers,
> especially to the CZ-5000, but I'd really like to learn more about it.
> Here's where I'd like some help or perhaps some further guidance
> from you my fellow friends.
> First of all, I'd like to hook the cz-5000 to my computer, but I'm
> not sure what kind of MIDI controller would do the job for me?
> (Again, I'm really new to all of this, so I'm already sorry for
> those whom I which am possibly boring the hell out of by now)
You need MIDI interface between your computer and world of MIDI. Which
one it depends on your OS and hardware, probably you can get some USB/
MIDI interface, instal driver if necessary and then your computer can
communicate with MIDI instruments - receive and transmit MIDI data.
> Secondly, I saw that there were a wide range of "patches" available
> for the CZ range, but I'm not sure how I can bring these on to my
> CZ-5000?
It depends on their format. Some are in text format, or graphics, such
patch sheets you have to set manually directly on the instrument, and
then save patch one by one to the internal memory. It's lot of work...
Better to use SysEx bulk dumps. You need some software for sending
MIDI files (extension MID, some patches can be in this format) and for
receiving/sending SysEx files (extension SYX). It can be special
application just for receiving and sending such data, or sequencer, or
librarian/bankloader application, or CZ editor. Which one? It depends
again on your OS.
You should know that there were some difficulties with SysEx
communication but I suppose it was solved. Check some previous threads
on this forum...
> And finally, as I bought the CZ-5000 without any RA-3 cartridge I
> was thinking if this would bring me any difficulties for what I'd
> like to use the synthesiser for?
Forget about the cartridge, it will not add more sounds like
cartridges on other instruments (Yamaha, Roland, Korg...), it can be
used just for saving internal memory data and loading them back.
There's no direct access to sound bank saved on the cartridge.
Same function (that means saving internal memory data and loading them
back) you can do with computer.
> Thanks for reading so far
> Have a good one
> Cheers
> Oli
Alles Gute!
MfG
Daniel Forro
2014-10-18 by Lee
Lack of a cartridge diminishes the number of sounds capable if being stored on board. This is not a problem if you use midi sysx to backup files to a pc.
I use
http://www.midiox.com/
To do this. As i recall the cz s have no ability to give up their
memory contents on the unit and must be sent sysx codes to eject them.
Details of communicating with the cz are at
Http://templarseries.atspace.com/cz.html
Along with pdf manuals and other sysx tips.
Lee
On 13 Oct 2014, at 22:42, "oliver.mentel@... [CZsynth]" <CZsynth@yahoogroups.com> wrote:
> I was just lucky enough to stumble over a 1985 CZ-5000 at my local music shop the other day and couldn't resist myself from not getting my hands on it.
> I'm pretty certain, that this may have been on of my best buys for the last few years!
> I'm pretty new to this whole exciting world of synthesizers, especially to the CZ-5000, but I'd really like to learn more about it.
> Here's where I'd like some help or perhaps some further guidance from you my fellow friends.
> First of all, I'd like to hook the cz-5000 to my computer, but I'm not sure what kind of MIDI controller would do the job for me? (Again, I'm really new to all of this, so I'm already sorry for those whom I which am possibly boring the hell out of by now)
> Secondly, I saw that there were a wide range of "patches" available for the CZ range, but I'm not sure how I can bring these on to my CZ-5000?
> And finally, as I bought the CZ-5000 without any RA-3 cartridge I was thinking if this would bring me any difficulties for what I'd like to use the synthesiser for?
> Have a good one
> Cheers
> Oli
2014-10-23 by Daniel Forró
Are you sure about it?
AFAIK cartridge on CZ can't expand a number of directly accessible
sounds. It serves only for saving data from internal RAM.
Of course after saving internal data to cartridge we can load other
data from the other cartridge, or fill the memory by sending SysEx
file. When we want to return data saved on the cartridge, it's
possible but internal data are erased by this.
VZ is different, sound programs on its RAM card are directly
accessible, so card expands total number of sounds.
Daniel Forro
> stored on board.
After comparing owner's manual I see I was wrong... It's many years when I had CZ101, CZ1000, VZ10M and VZ1... Last few years I have again CZ, this time CZ3000, so I was confused.
With cartridge it is so (if I understand well):
CZ1/101/1000 has direct access to the sounds on the cartridge. Cartridge expands number of onboard sounds. It's possible to write only one sound program to the cartridge memory locations, or to Save or Load whole bank of sounds. CZ1 has also possibility to exchange one selected sound on the cartridge with the same location sound in internal RAM.
CZ3000/5000 doesn't have direct access to the sounds stored on cartridge, cartridge is used only for backup of internal RAM (Save) and data saved on the cartridge must be loaded into RAM to be used.
Daniel Forro
AFAIK cartridge on CZ can't expand a number of directly accessible sounds. It serves only for saving data from internal RAM.
Of course after saving internal data to cartridge we can load other data from the other cartridge, or fill the memory by sending SysEx file. When we want to return data saved on the cartridge, it's possible but internal data are erased by this.
VZ is different, sound programs on its RAM card are directly accessible, so card expands total number of sounds.
Daniel Forro
