> I have many devices in my muzik room, (a couple hundred). I turn them
> all on and off at the same time EXCEPT Amps. I have a couple power
> strips plugged in ahead of the main one to leave some things powered
> up 24/7. Of course, this means that if you lose house power, you'll
> lose data. Mainly it saves the memory batteries for when I DO need them.
> Rig
> On Tue, 7/12/16, Caleb Garner caleb.garner@... [CZsynth]
> <CZsynth@yahoogroups.com> wrote:
> Subject: Re: [CZsynth] Best backup battery solution for CZ-1000?
> To: CZsynth@yahoogroups.com
> Date: Tuesday, July 12, 2016, 10:13 AM
> replying to both emails in
> here more or less:
> - cool about the battery.. yea that diode makes me
> nervous.. no idea
> where that would go..
> - yes changing batteries once a year isn't the worst
> thing to do.. i'll
> probably be ok with it once i get Unisyn installed with
> DP3.. so I can
> actually send / receive sysex patches from it.. this way
> patches get
> saved with songs and dump backups can be sent / pulled any
> time.. i
> have the cartridge with a fresh battery so that's
> safe.. and the 16
> internal could be restored literally as needed when doing a
> session..
> so there's that :) I have midiquest11 which is
> great, but doesn't
> run on OS9.. So unisyn will have to do for most things.
> - i get it.. it could be risky.. but then i have a number of
> pieces of
> gear that the engineers left off power switches. ART is
> especially
> notorious for that.. I will probably do a few things but
> I'm going to
> trust things like wall warts to handle the power surge since
> they are
> outside the gear.. basically things i especially prize
> or are
> exceptionally old like my Mirage and Akai S612.. The casio
> will get the
> treatment since for now I'm not going to mess with
> diodes personally
> unless I can find someone locally to help out with it..
> things like my
> fender quad reverb i don't turn on like that..
> that's very very old and
> something i don't use all that often anyway..
> - do have items with sketchy / close to breaking buttons on
> things..
> like my digitech RDS delay.. it works still but the
> "joint" it pivots on
> is wearing out and it's "this close" to
> popping out.. are most of my
> buttons ok? yes.. but the article spoke to me about this
> because i
> could relate to his point.
> - so yea i see enough high end pros doing it to not be too
> worried and
> in reality most of the stuff I have is not really very
> valuable.. so
> it's not like i have racks of Moogs and such.. but yea
> as i said a few
> gems (to me) I might give a little extra love too just for
> good karma..
> - yea i always turn down the audio for my speakers / mixer
> to avoid any
> popping sounds.. that seems to do the trick to prevent
> anything from
> being hurt turning on/of
> Thanks! :)
> Caleb
> Gordonjcp gordon@...
> [CZsynth] wrote:
> On Mon, Jul 11, 2016 at 04:23:09AM -0400, Caleb
> Garner
> caleb.garner@...
> [CZsynth] wrote:
> > I use a power conditioner as the main switch, so that
> also helps
> insure
> > regulating power and avoiding spikes..
> That's a good idea but won't help with the inrush
> current of suddenly
> switching all the gear on simultaneously.
> The power ratings are the continuous load, it says nothing
> about the big
> surge as all those smoothing capacitors charge up and that
> is a fair
> old whack.
> > however not to assume too much I found this thread and
> as you can
> see
> > yes some opinions are varied but there are guys in here
> who have
> done it
> > for many many years and even some pointing out the
> advantage of not
> > wearing out the on/off switches of aging gear.
> Can't say I've ever seen a worn-out on/off switch.
> I'm not saying it
> can't happen, but it wouldn't be the first failure
> mode I'd look for,
> put it that way.
> > but yea what I'm trying to do is figure out how I
> can remove the
> need
> > for using D batteries as a backup since I'm not
> planning on playing
> this
> > thing portably though I wouldn't mind keeping that
> ability of
> course.
> Look at how synths that use Nicad or coin cell batteries (or
> like the
> Kurzweils, a stack of HP7s in an easily-accessible hatch
> underneath) for
> memory backup.
> Basically you want to cut the supply to the RAM chip and add
> a diode
> from +5V to the chip, and then add a backup battery with a
> diode to stop
> the +5V rail trying to charge it.
> Gordonjcp MM0YEQ
> #yiv8445841304 #yiv8445841304 --
> #yiv8445841304ygrp-mkp {
> border:1px solid #d8d8d8;font-family:Arial;margin:10px
> 0;padding:0 10px;}
> #yiv8445841304 #yiv8445841304ygrp-mkp hr {
> border:1px solid #d8d8d8;}
> #yiv8445841304 #yiv8445841304ygrp-mkp #yiv8445841304hd {
> color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
> 0;}
> #yiv8445841304 #yiv8445841304ygrp-mkp #yiv8445841304ads {
> margin-bottom:10px;}
> #yiv8445841304 #yiv8445841304ygrp-mkp .yiv8445841304ad {
> padding:0 0;}
> #yiv8445841304 #yiv8445841304ygrp-mkp .yiv8445841304ad p {
> margin:0;}
> #yiv8445841304 #yiv8445841304ygrp-mkp .yiv8445841304ad a {
> color:#0000ff;text-decoration:none;}
> #yiv8445841304 #yiv8445841304ygrp-sponsor
> #yiv8445841304ygrp-lc {
> font-family:Arial;}
> #yiv8445841304ygrp-lc #yiv8445841304hd {
> margin:10px
> 0px;font-weight:700;font-size:78%;line-height:122%;}
> #yiv8445841304ygrp-lc .yiv8445841304ad {
> margin-bottom:10px;padding:0 0;}
> #yiv8445841304 #yiv8445841304actions {
> font-family:Verdana;font-size:11px;padding:10px 0;}
> #yiv8445841304 #yiv8445841304activity {
> background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
> #yiv8445841304 #yiv8445841304activity span {
> font-weight:700;}
> #yiv8445841304 #yiv8445841304activity span:first-child {
> text-transform:uppercase;}
> #yiv8445841304 #yiv8445841304activity span a {
> color:#5085b6;text-decoration:none;}
> #yiv8445841304 #yiv8445841304activity span span {
> color:#ff7900;}
> .yiv8445841304underline {
> text-decoration:underline;}
> #yiv8445841304 .yiv8445841304attach {
> clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
> 0;width:400px;}
> #yiv8445841304 .yiv8445841304attach div a {
> #yiv8445841304 .yiv8445841304attach img {
> border:none;padding-right:5px;}
> #yiv8445841304 .yiv8445841304attach label {
> display:block;margin-bottom:5px;}
> #yiv8445841304 .yiv8445841304attach label a {
> #yiv8445841304 blockquote {
> margin:0 0 0 4px;}
> #yiv8445841304 .yiv8445841304bold {
> font-family:Arial;font-size:13px;font-weight:700;}
> #yiv8445841304 .yiv8445841304bold a {
> #yiv8445841304 dd.yiv8445841304last p a {
> font-family:Verdana;font-weight:700;}
> #yiv8445841304 dd.yiv8445841304last p span {
> margin-right:10px;font-family:Verdana;font-weight:700;}
> span.yiv8445841304yshortcuts {
> margin-right:0;}
> #yiv8445841304 div.yiv8445841304attach-table div div a {
> #yiv8445841304 div.yiv8445841304attach-table {
> width:400px;}
> #yiv8445841304 div.yiv8445841304file-title a, #yiv8445841304
> div.yiv8445841304file-title a:active, #yiv8445841304
> div.yiv8445841304file-title a:hover, #yiv8445841304
> div.yiv8445841304file-title a:visited {
> #yiv8445841304 div.yiv8445841304photo-title a,
> #yiv8445841304 div.yiv8445841304photo-title a:active,
> #yiv8445841304 div.yiv8445841304photo-title a:hover,
> #yiv8445841304 div.yiv8445841304photo-title a:visited {
> #yiv8445841304 div#yiv8445841304ygrp-mlmsg
> #yiv8445841304ygrp-msg p a span.yiv8445841304yshortcuts {
> font-family:Verdana;font-size:10px;font-weight:normal;}
> #yiv8445841304 .yiv8445841304green {
> color:#628c2a;}
> #yiv8445841304 .yiv8445841304MsoNormal {
> margin:0 0 0 0;}
> #yiv8445841304 o {
> font-size:0;}
> #yiv8445841304 #yiv8445841304photos div {
> float:left;width:72px;}
> #yiv8445841304 #yiv8445841304photos div div {
> border:1px solid
> #666666;min-height:62px;overflow:hidden;width:62px;}
> #yiv8445841304 #yiv8445841304photos div label {
> color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
> #yiv8445841304 #yiv8445841304reco-category {
> font-size:77%;}
> #yiv8445841304 #yiv8445841304reco-desc {
> font-size:77%;}
> #yiv8445841304 .yiv8445841304replbq {
> margin:4px;}
> #yiv8445841304 #yiv8445841304ygrp-actbar div a:first-child {
> margin-right:2px;padding-right:5px;}
> #yiv8445841304 #yiv8445841304ygrp-mlmsg {
> font-size:13px;font-family:Arial, helvetica, clean,
> sans-serif;}
> #yiv8445841304 #yiv8445841304ygrp-mlmsg table {
> font-size:inherit;font:100%;}
> #yiv8445841304 #yiv8445841304ygrp-mlmsg select,
> #yiv8445841304 input, #yiv8445841304 textarea {
> font:99% Arial, Helvetica, clean, sans-serif;}
> #yiv8445841304 #yiv8445841304ygrp-mlmsg pre, #yiv8445841304
> code {
> font:115% monospace;}
> #yiv8445841304 #yiv8445841304ygrp-mlmsg * {
> line-height:1.22em;}
> #yiv8445841304 #yiv8445841304ygrp-mlmsg #yiv8445841304logo {
> padding-bottom:10px;}
> #yiv8445841304 #yiv8445841304ygrp-msg p a {
> font-family:Verdana;}
> p#yiv8445841304attach-count span {
> color:#1E66AE;font-weight:700;}
> #yiv8445841304 #yiv8445841304ygrp-reco
> #yiv8445841304reco-head {
> color:#ff7900;font-weight:700;}
> #yiv8445841304 #yiv8445841304ygrp-reco {
> margin-bottom:20px;padding:0px;}
> #yiv8445841304 #yiv8445841304ygrp-sponsor #yiv8445841304ov
> li a {
> font-size:130%;text-decoration:none;}
> li {
> font-size:77%;list-style-type:square;padding:6px 0;}
> ul {
> margin:0;padding:0 0 0 8px;}
> #yiv8445841304 #yiv8445841304ygrp-text {
> font-family:Georgia;}
> #yiv8445841304 #yiv8445841304ygrp-text p {
> margin:0 0 1em 0;}
> #yiv8445841304 #yiv8445841304ygrp-text tt {
> font-size:120%;}
> #yiv8445841304 #yiv8445841304ygrp-vital ul li:last-child {
> border-right:none !important;
> #yiv8445841304
