Dave Smith Instruments SYNTHESIZERS group photo
Index last updated: 2026-04-28 22:43 UTC
play different programs in cubase
2009-01-28 by chuckchilloutfr
hello everybody,
I've got my PEK since few days and I'm struggling with combis and
sequences ! Manual is not very clear for me, especially the way of
using the 4 sequencers and combis.
I use Cubase LE and (for exemple) in my arrangement I would like to set
midi tracks like this :
- midi track 1 route to : PEK's midi channel 1, to play program 4)
- midi track 2 route to : PEK's midi channel 2, to play program 115)
- midi track 3 route to : PEK's midi channel 3, to play program 37)
- midi track 4 route to : PEK's midi channel 4, to play another
program's sequence
How can I set the PEK for that ?
Also I noticed that sequences play automatically as I start playback in
cubase ! Is it possible to avoid it ?
RE: [DSI Synths] play different programs in cubase
2009-01-30 by Iain Bryden
Unfortunately The Poly Evolver won't work that way. You can't send a
patch change to an individual part. This is contrary to the DSI claim
that a "Poly Evolver is just like having four Mono Evolvers." This is
why I sold my Rack and use an MEK and Desktop.
Start/Stop of the sequencer is also a problem. I haven't found a way to
trigger the sequencer whenever I want. The only way I found around this
was to record a sequence to an audio track, then drag the audio track to
where I want it in the song. For this reason I rarely use the sequencer.
Too bad because otherwise its great.
These two issues are unforgivable in my opinion. I'm sure DSI knows
about them because I (and probably others) emailed DSI about them, and
they're generally good about reading their emails.
-- Iain
From: DSI_Evolver@yahoogroups.com [mailto:DSI_Evolver@yahoogroups.com]
On Behalf Of chuckchilloutfr
Sent: Wednesday, January 28, 2009 4:44 PM
To: DSI_Evolver@yahoogroups.com
Subject: [DSI Synths] play different programs in cubase
hello everybody,
program's sequence
This electronic mail message contains information that (a) is or
may be CONFIDENTIAL, PROPRIETARY IN NATURE, OR OTHERWISE
PROTECTED
BY LAW FROM DISCLOSURE, and (b) is intended only for the use of
the addressee(s) named herein.  If you are not an intended
recipient, please contact the sender immediately and take the
steps necessary to delete the message completely from your
computer system.
Not Intended as a Substitute for a Writing: Notwithstanding the
Uniform Electronic Transaction Act or any other law of similar
effect, absent an express statement to the contrary, this e-mail
message, its contents, and any attachments hereto are not
intended
to represent an offer or acceptance to enter into a contract and
are not otherwise intended to bind this sender,
barnesandnoble.com
llc, barnesandnoble.com inc. or any other person or entity.
Re: [DSI Synths] play different programs in cubase
2009-01-30 by Filch
Yes, it is possible. Check the manual section for Global and Clock Settings
2009-01-30 by Stefan Trippler
I use the mode "key triggers and resets sequencer" for that. Works
flawlessly.
To: <DSI_Evolver@yahoogroups.com>
Sent: Friday, January 30, 2009 5:44 PM
Subject: RE: [DSI Synths] play different programs in cubase
-- Iain
hello everybody,
program's sequence
PROTECTED
computer system.
intended
barnesandnoble.com
2009-02-02 by chuckchilloutfr
playback in
Settings
Yes, when Clock is set to INTERNAL I can start/play sequences manualy,
but the synth is not sync with the PC anymore..  Is it possible to
trig the sequence only when I hit a key instead of start/stop button ?
